getting a sh!tload of errors after replacing header, need help asap
Old May 11, 2007 | 04:49 AM
smeck's Avatar
Default getting a sh!tload of errors after replacing header
I swapped my f20a4 for a jdm h22a (both obd2). and after about 400km without any problems I suddenly got some errors, fixed em all exept error code 7, and I thought this was because the tps was only set with 1 instead of 2 bolts. so I went to the garage last week to get it checked for anual safety inspection, and was told it had about 4 times the max emission allowed. so it failed the inspection meaning I'm not allowed to drive it untill it's fixed (I'm living in holland, europe)
So i decided to replace the stock header (which wasn;t that good anyway) with a ss 4-2-1 from obx. but after replacing the header i got the following error codes:
3 Manifold Absolute Pressure Signal
7 Throttle Position Circuit
10 Intake Air Temperature Cicuit
20 Electrical Load Detector Circuit
41 Primary Heated Oxygen Circuit
does anyone have a clue wtf is going on???
Modified by smeck at 12:43 PM 5/11/2007
Modified by smeck at 4:06 PM 5/11/2007
Old May 11, 2007 | 11:43 AM
smeck's Avatar
Default Re: getting a sh!tload of errors after replacing header, need help asap (smeck)
anyone?
Old May 11, 2007 | 03:20 PM
AndrePerras's Avatar
Default Re: getting a sh!tload of errors after replacing header (smeck)
sounds like you unhooked a ground or something
Old May 11, 2007 | 03:23 PM
smeck's Avatar
i installed a 5point ground wirekit, so guessing that's not it, but gonna check it anyway
BlownH23a
Guest
Posts: n/a
wow that must be a pain...have you inspected the entire harness for damage?
Old May 11, 2007 | 03:26 PM
smeck's Avatar
just quickly, maybe the lambda sensor got damaged when replacing the header, but then I've still got the tps error
Old May 11, 2007 | 03:38 PM
BlownH23a
Guest
Posts: n/a
yea not to mention 3, 7, 10, 20. You must have crossed something and fried your electrical.
Old May 11, 2007 | 03:41 PM
smeck's Avatar
Default Re: (BlownH23a)
yeah that's what i'm affraid of. having it checked out at a specialized honda tuning company in the area next week, and hope it's just some wires, worst case scenario i'll have to get a new ecu but then again...i'll be rid of the speedlimiter
Old May 12, 2007 | 03:18 PM
smeck's Avatar
Default Re: (smeck)
but no clues what could be causing the code 7 error?
Since I got the error it fires up normal but jumps up about 200/300rpm (900>1200) after a few seconds, then returns to normal, but none of the possible sollutions seem to be working
ThA5oLuTiOn
Aug 10, 2008 04:14 PM
RED_90TEG
May 11, 2008 01:25 PM
JDMlyfestyle
Jul 16, 2004 11:26 PM
ScottEK
Oct 20, 2002 08:35 PM
