CHugging 2001 Prelude
Old May 11, 2007 | 09:53 AM
bethe's Avatar
Default CHugging 2001 Prelude
My 2001 Prelude (150000km) makes a cyclical chugging noise at idle that becomes consistently more frequent as the engine speeds up. It doesn't stall but it runs rough in low gears. ANy ideas what the problem might be?
Old May 11, 2007 | 10:05 AM
4WSi_guy's Avatar
Default Re: CHugging 2001 Prelude (bethe)
Sounds like a dead miss....change plugs..check wires very closely for burn indications or breaks in the wire....inspect cap and rotor for burn indications....report back
Old May 11, 2007 | 10:15 AM
bethe's Avatar
Default Re: CHugging 2001 Prelude (4WSi_guy)
Thanks Very Much. I went and got plugs, rotor and cap an hour ago! Wires look good. Will install in about an hour. I'll keep my fingers crossed and let you know. ANy installation tips for these components would be appreciated!
Old May 11, 2007 | 10:21 AM
4WSi_guy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bethe &raquo;</TD></TR><TR><TD CLASS="quote"> ANy installation tips for these components would be appreciated</TD></TR></TABLE>
I would check your old cap and rotor....you will see indications of an ignition arc on them...if you dont see anything I woulnd't replace them personally...also let the motor cool b4 you change the plugs...some folks dont do it...I think its good considering its an aluminum head..thats about it....GL
Old May 14, 2007 | 08:38 AM
bethe's Avatar
Changed plugs, rotor and cap...all were well coked, so the performance delta is very good. Still have the chuga noise noise. I expect that's from something loose in the exhaust. Will investigate this weekend. Thx again for your help!
Old May 16, 2007 | 08:39 AM
4WSi_guy's Avatar
does this "chuga" change when you pull any spark plug wires while the car is running?
Old May 16, 2007 | 09:17 AM
zirac50's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bethe &raquo;</TD></TR><TR><TD CLASS="quote">My 2001 Prelude (150000km) makes a cyclical chugging noise at idle that becomes consistently more frequent as the engine speeds up. It doesn't stall but it runs rough in low gears. ANy ideas what the problem might be?</TD></TR></TABLE>
check the spark plug wires firing order. If it's not in the right firing order you get "chug" noise. But if that does not help, check fuel system make sure all injectors are working properly. It's also better to clean you intake system as well as the EGR and IACV. Last choice is to run compression test that could be low compression on one of those cylinder.
01blklude
Jul 23, 2009 08:38 PM
paboshon
Aug 14, 2008 12:59 PM
justinhood
Nov 23, 2007 01:28 PM
sosicman
Dec 5, 2006 11:24 AM
95vtecgook
Apr 28, 2003 07:35 AM
