code 23 knock sensor when going over 40 mph
Old May 8, 2007 | 11:20 AM
djsire's Avatar
Default code 23 knock sensor when going over 40 mph
it only comes on when i go over 40.
can somoen advise me.
Old May 8, 2007 | 02:09 PM
MilanoLude's Avatar
Default Re: code 23 knock sensor when going over 40 mph (djsire)
Exactly 40mph or just high speeds?
What happened with mine is at freeway speeds, no specific mph, I would get a CEL. Turned out my knock sensor had busted in half where the plastic piece is joined.
Old May 8, 2007 | 02:20 PM
BlownH23a
Guest
Posts: n/a
just replace the knock sensor, you can get them for like 40 bucks off ebay..a b series will work with the H series. see ya.
Old May 9, 2007 | 10:51 AM
djsire's Avatar
Default Re: (BlownH23a)
turned out to be the wire was exposed.
i guess wind speed mad it jiggle and short on the block.
tapped it up and its running great!
Old May 9, 2007 | 11:06 AM
BlownH23a
Guest
Posts: n/a
Default Re: (djsire)
good to hear you got it fixed...the knock sensor wire can be a pain in the ***...i put a silicone sleeve on mine so that exact problem didnt happen.
Old May 10, 2007 | 09:22 AM
djsire's Avatar
yea there was a piece of rubber wire sleeve near by the splice.
i just taped up the splice and pulled the sleeve over it and taped that too so it would protect it.
civiconfire
Sep 10, 2006 07:31 PM
quicky_hatch12
Oct 7, 2005 11:59 AM
92HatchB16
Oct 1, 2005 05:05 PM
EF_LSVtec
Apr 10, 2003 11:25 AM
