Replacing doors? (trim issues...window issues....)
Old May 10, 2007 | 11:07 AM
JDMgareth's Avatar
Default Replacing doors? (trim issues...window issues....)
After looking at the horrible trim on my door I tried to search OEM honda whole salers for the part i need to replace...the more I looked, the more I couldn't see if its actually a part or actually a peice of the entire door...
Door trim pic #1:
as you can see the trim piece is almost all ripped off and the chrome is now almost all showing. I can't even seem to find if this is something I can replace since I can't find the part in OEM part store schematics.
Roof Trim pic #1:
Can't find this top trim either to replace. Is it something I can find at http://www.bkhondparts.com (or another site you guys prefer?)
Rear window trim #1:
Another seemingly easy part to find, that I can't see to...Just looking for the oem trim part around the rear windows.
1 Last thing, I have 3-4 verticle scratches up my driver's side window from when I first bought the car. Before replacing the window, in your opinion do you think it was human caused, or maybe bushings on the wheel parts inside the door that are missing or scratching the window? When I roll the window all the way down, towards the very end it shakes and rumbles to a stop.
I appreciate any insight and I have hunted a long while through OEM part drawings trying to find these pieces...I'm not sure if theres a trick or I'm looking in the wrong section of the car. I appreciate any help, and thanks a lot!
Old May 10, 2007 | 03:08 PM
JDMgareth's Avatar
Went to honda dealer ship about 3 months ago, and they quoted me a rough 1000$ to replace all weather stripping.
Anyone know if the wrecked parts above can be ordered/replaced?
*bump
Old May 10, 2007 | 04:27 PM
SnlpeR's Avatar
according to the helms...
you have to remove the glass on the doors before you can unclip the molding
Old May 10, 2007 | 04:43 PM
95SE's Avatar
Default Re: (SnlpeR)
Part #'s 5 and 6 = I do not think that you can replace only the trim.
http://www.hondaautomotivepart...GLASS
Door schematic
http://www.hondaautomotivepart...PANEL
I can't find the damn roof things.
good luck
Old May 10, 2007 | 04:57 PM
m00nr0ck Si's Avatar
Default Re: (95SE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95SE &raquo;</TD></TR><TR><TD CLASS="quote">
good luck</TD></TR></TABLE>
part # 7 & 8
https://www.hondapartsdeals.co...+4210
Old May 10, 2007 | 05:59 PM
95SE's Avatar
Default Re: (dorkoftheyear)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dorkoftheyear &raquo;</TD></TR><TR><TD CLASS="quote">
part # 7 & 8
https://www.hondapartsdeals.co...+4210</TD></TR></TABLE>
holy crap $75 for those things!
Old May 10, 2007 | 06:07 PM
JDMgareth's Avatar
OK!!!! We are getting some where! i'm so happy.
So. Found the rear window linings, and the roof linings, but where is the door/window trim piece like in the first picture (the chrome part?)
Old May 10, 2007 | 06:11 PM
Default Re: (JDMgareth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMgareth &raquo;</TD></TR><TR><TD CLASS="quote">OK!!!! We are getting some where! i'm so happy.
So. Found the rear window linings, and the roof linings, but where is the door/window trim piece like in the first picture (the chrome part?)</TD></TR></TABLE>
# 3 & #6
and umm, they are coated in black rubber paint from the factory...which you prob. already knew...www.hondapartsdeals.com has everything , along with the best prices and fast shipping.
Old May 10, 2007 | 06:48 PM
ludeing1's Avatar
the roof trim pieces and the door glass weather seal can be sanded, primed and painted then cleared. the quarter glass trim is not going to be a easy thing to find , paint or replace.
Old May 10, 2007 | 06:59 PM
zirac50's Avatar
Default Re: Replacing doors? (JDMgareth)
hehehe.. honda dealer charge you $56 dollars if you buy one of those trim on the door. I got mine from junk yard and looks good now. If you get one to your door, get the rubber coated cuz they last long, I got mine from 01 base. The 99 SH I got was peeling cuz I don;t now what type of material was that but Im sure that wasn't a rubber on the top of the chrome. They are really easy to install on the door only take 30 mins.
Only thing you have to unscrew is the power mirror and you have to start from that point and pull the crap. those clips are hard..
Old May 11, 2007 | 11:52 AM
JDMgareth's Avatar
ludeing1: <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">the quarter glass trim is not going to be a easy thing to find</TD></TR></TABLE>
So, the rear quarter-glass windows don't come with the rubber stripping from honda?
ie) http://www.hondaautomotivepart...GLASS
5 & 6 is just glass, no rubber stripping around the edge?
Old May 11, 2007 | 12:21 PM
Serenity Now!'s Avatar
https://honda-tech.com/zerothread?id=1688878
or you can do this DIY to "fix it"
Old May 11, 2007 | 02:51 PM
rch022's Avatar
your best bet is the junkyard, tahts if you can find a lude, you'll save tons of $$$$, GL
Old May 11, 2007 | 03:08 PM
JDMgareth's Avatar
How exactly do junkyards work? Don't laugh, we all had a first-time at a junkyard.
But what is the process you go through to get something from a junkyard?
Old May 12, 2007 | 07:22 AM
rch022's Avatar
my first time at the junkyard was actually 2 days ago haha, but some are pick and pull where they let you go in and find your parts on your own(cheaper and more fun) or some you have to tell them waht you need and they'll get the parts. but most likely you will save money
Old May 12, 2007 | 08:01 AM
93sivtec's Avatar
I know it sounds ghetto,but I actually used black vinyl to cover all the spots you are talking about replacing,and it looks good,very hard to notice even close,I did the rain ducts on top,and the door sils that turn to chrome.
First I used black tape and my friend who does vinyl laughed at me and hooked me up w some of his heavy duty vinyl he uses for sign/stickers,I hooked it up like that.
Old May 12, 2007 | 08:08 AM
rch022's Avatar
Default Re: (93sivtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93sivtec &raquo;</TD></TR><TR><TD CLASS="quote">I know it sounds ghetto,but I actually used black vinyl to cover all the spots you are talking about replacing,and it looks good,very hard to notice even close,I did the rain ducts on top,and the door sils that turn to chrome.
First I used black tape and my friend who does vinyl laughed at me and hooked me up w some of his heavy duty vinyl he uses for sign/stickers,I hooked it up like that.</TD></TR></TABLE>
got any pics of this?
Old May 12, 2007 | 10:37 AM
JDMgareth's Avatar
Think I might try the door chrome trim DIY. I'll do pics to see how it turns out.,
Old May 12, 2007 | 01:30 PM
prahjekt's Avatar
"So, the rear quarter-glass windows don't come with the rubber stripping from honda?"
I just had all my stripping replaced when my car went to a body shop(except for the quarter-glass stripping). I was told the stripping for the rear quarter-glass window is attached to the glass, so essentially it's one piece.
I had the "rails" on my roof repainted and cleared, but within a year's time they started to chip again. Since my car is black, I'm planning to have them repainted with a black, self etching primer that shouldn't flake off. I'm not going to worry about the clear though, it'll just flake off again. They're obviously problem areas.
Old May 12, 2007 | 09:07 PM
Rosko's Avatar
Default Re: (prahjekt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prahjekt &raquo;</TD></TR><TR><TD CLASS="quote">"So, the rear quarter-glass windows don't come with the rubber stripping from honda?"
yeah its kinda molded around the window on both sides, it doesn't come off. I just replaced the two windows on mine but that was a bitch to get the old windows out.
EG_Warped
Dec 26, 2008 02:39 PM
.Nomad.
Nov 4, 2006 08:49 AM
cwood1388
Jun 5, 2006 11:53 PM
89 pos
Sep 25, 2005 09:34 PM
Ding
16
Mar 5, 2005 05:24 AM
