EL gauge problem
Old May 12, 2007 | 11:07 PM
outlawstar27's Avatar
Default EL gauge problem
ok guys i need help. i have a 92 prelude si. i got my friends digital gagues. i also have a 94-96 harness. well everything seems to be working fine except when i turn the left or right indicators, it shows the hazzards. everything works fine outside but inside it just shows hazzards flashing. but when i put the hazzards on...nothing shows. well i read on here that i have to ground a certain black wire. how exactly do i ground this? any help please!
Old May 13, 2007 | 09:17 AM
Ludster's Avatar
Default Re: EL gauge problem (outlawstar27)
You can ground it by getting a self-tapping screw and attach it to the body of the car. make sure you grind down the paint so you see the bare metal. It will give you good grounding point.
Inside the passenger kick panel has a lot of room to ground the wire, since the wire you need to ground is in the 3-wire connector on that side.
girliehonda
Dec 6, 2007 03:58 AM
thejacka
Audio / Security / Video
Jul 10, 2006 11:03 PM
AspectIndustries
Welding / Fabrication
Oct 3, 2004 05:09 PM
Civic96LX
Nov 10, 2003 04:11 AM
garyyam
Oct 22, 2002 04:05 PM
