Poor man's Bpi flowstack
Old May 12, 2007 | 01:28 PM
BlueJdm's Avatar
Default Poor man's Bpi flowstack
I took my filter out today to clean it, and got an idea. I remembered seeing a velocity stack at autozone and I always thought it just might fit into my filter. So I figured what hell why not waste the 20 bucks for the stack to see if it would fit and to my surprise it fit perfectly into the filter. I had to do a little cutting of the filter but basically the outer shell of it fits perfectly over top the velocity stack.
Advanced auto filter
Autozone velocity stack
The only part of the filter i had to cut was just on the inside, which was easy because the filter came in two pieces. There was a bolt on top that held it together and once that was removed I pulled the inner shell out and just reinstalled the top part of it with the screw on top.
Part the was cut off that you don't need.
Small part of inner shell that was reinstalled inside the filter to hold the foam in place
Then I just took the velocity stack and pressed it up in the bottom of the filter, it was such a good tight fit I didn't even need anything to secure the velocity stack and the outer shell of the filter together. But i did have to stick my hand up the hole and pushed some of the foam down around the outer edges.
Here's the filter installed. I still need to cut about 2-3 inches off the end of the pipe to make it fit better but you get the idea.
I took a test drive around the block, but I didn't really get chance to test it out at full throttle for more than a couple of seconds, but I did notice a definite decrease in the mid range power dip, and the entire power band just seemed to be a lot smoother. Definitely worth the 20 bucks to me.
Old May 12, 2007 | 01:47 PM
InvaderTrax's Avatar
Someone else had done one with the AutoZone stack, but not like that. Good idea
Old May 12, 2007 | 02:35 PM
Mykizism's Avatar
Default Re: Poor man's Bpi flowstack (BlueJdm)
jesus. that advance auto filter looks exactly like a greddy air inx air filter setup.. except greddy is blue..
talk about rip off..
Old May 12, 2007 | 02:54 PM
BlownH23a
Guest
Posts: n/a
yea just dye the filter blue and you have yourself a greddy for a 10th the cost haha
Old May 12, 2007 | 03:11 PM
Buffalo's Avatar
Default Re: (BlownH23a)
greddy airnix replacement foam comes in varoius colors
Old May 12, 2007 | 03:18 PM
BlueJdm's Avatar
Default Re: (Buffalo)
Yeah I think the filter cost me about 20 bucks, which was the reason I originally bought it because it was cheaper than the cone style filters they had.
Ritchie
10
Jan 18, 2007 05:59 PM
hamadiscool
Nov 5, 2006 10:09 PM
slvrstns2000
Jun 7, 2006 09:25 AM
