Overheating
Old May 7, 2007 | 08:08 PM
mike3's Avatar
Default Overheating
Hey guys, I rebuilt my engine last fall with 11.5:1 comp pistons, a cam, rods ect. Anyways since the build when Im stuck in traffic or at idle when its warm outside it just starts overheating. Like the gauge goes all the way into the red. But as soon as I start driving at like 30-40 mph it cools down. It never did this before, and I dont know why its happening.
BTW- The fans come on, the coolant level is full and i replaced the rad right before the build. Any ideas?
Old May 7, 2007 | 08:12 PM
mike3's Avatar
Default Re: Overheating (mike3)
BTW I just replaced the thermotat a before the build, and both rad hoses are hot when the engine is running
Old May 7, 2007 | 08:13 PM
SKDRCR's Avatar
Is the coolant circulating good?
Old May 7, 2007 | 08:15 PM
Hawkze_2.3's Avatar
Could still have air in the system...
Old May 7, 2007 | 08:25 PM
mike3's Avatar
There is no air in the system either. its been bled
Old May 7, 2007 | 08:27 PM
Hawkze_2.3's Avatar
Default Re: (mike3)
Does the fan come on (sounds like it's not)? Could be a bad fan switch...
Old May 7, 2007 | 08:28 PM
vinuneuro's Avatar
Sounds like the fan isn't turning on.
Old May 7, 2007 | 08:38 PM
mike3's Avatar
Default Re: Overheating (vinuneuro)
I have stated that the fans come on. I physically got out of my car, popped the hood while it was running to check.
Old May 7, 2007 | 09:02 PM
Altilude's Avatar
I was having overheating problems last year, with everything (thermostat, fans, properly bled, new rad cap etc) working just as you said, to me it sounds like your rad is just past due. replace the rad if everything else is working. I put a nice koyo in mine.
Old May 7, 2007 | 09:11 PM
mike3's Avatar
The rad was just replaced
Old May 8, 2007 | 04:00 AM
upallnite's Avatar
Did you check the water pump when you rebuilt the motor? Maybe the bearing is going bad and it is not turning enough at idle. If that is happening you should be loosing coolant thru the weap hole on the pump.
Old May 8, 2007 | 07:09 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike3 &raquo;</TD></TR><TR><TD CLASS="quote">I have stated that the fans come on. I physically got out of my car, popped the hood while it was running to check.</TD></TR></TABLE>
It sounds like you have checked everything already, but it can't hurt to check again. A cooling system is not that complicated and it has to be one of only a few things...
Old May 8, 2007 | 03:36 PM
mattsnooz's Avatar
Default Re: Overheating (Hawkze_2.3)
i would say pump too. when you rev, pump rotates faster (forcing it to run faster even if pump is failing), therefor cooling when car at higher rmp. when at idle, less rpm, therefor not sufficient fluid movement at pump to cool car? does that sound possible?
mda56
Feb 19, 2011 01:44 PM
$amGD3
Jul 26, 2010 09:24 AM
vlude99
Jul 30, 2009 05:58 PM
Integra Integra
Dec 15, 2005 06:15 AM
CivicFerio
Jul 22, 2001 07:07 PM
