CEL at 50 mph
Old May 26, 2007 | 05:43 PM
LukieLuc's Avatar
Default CEL at 50 mph
Okay i just removed, my ac and PS. And i took my car out for a drive, now every time around 50 mph my check engine light turns on. I tried to jump the service conector but the CEL doesnt do anything. I think it is that sensor in one of the PS lines, going to the pump that i didnt disconect, could this be? Can anyone give me some insight on this?
Oh yea my intake filter is realllllllllllyyy dirty, and PS fluid dripped on and around the o2 sensor when i was removing the the Power steering.
I have a 1995 honda prelude with a JDM H22a thanks
Modified by LukieLuc at 10:10 PM 5/26/2007
Old May 27, 2007 | 08:41 AM
LukieLuc's Avatar
Default Re: CEL at 50 mph (LukieLuc)
Bump for answers
Old May 27, 2007 | 08:43 AM
mgags7's Avatar
The power steering pressure sensor does not throw a check engine light. You're not jumping the connector right if it is not flashing a code.
Keep in mind that a solid CEL means the ecu is f*cked, though I doubt thats your problem since it seems to be running ok otherwise.
One short blink means the o2 sensor is the fault.
Old May 27, 2007 | 08:56 AM
LukieLuc's Avatar
Default Re: (mgags7)
i am jumping it correctly, the CEL comes on when i go around 50 mph, not when i start the car.
I tried jumping it with a wire and paper clip
This is exactly what i am doing, then i turn the key to "on" All lights turn on the dash and then turn off including the CEL
Is there a way i can test my service connector?
Old May 27, 2007 | 11:06 AM
LukieLuc's Avatar
Default Re: (LukieLuc)
It happens faster when its hotter out like around 90
Old May 27, 2007 | 12:59 PM
LukieLuc's Avatar
HELP!!!!! ANY One????
Old May 27, 2007 | 01:29 PM
Vilmar's Avatar
It sounds like knock sensor.
It happened to me, when I was driving at 50mph it threw a cel, and it was the knock sensor, its code 23
Old May 27, 2007 | 04:44 PM
LukieLuc's Avatar
Default Re: (Vilmar)
Vtec still kicks in though, everything runs normaly
what should i do to correct this, and how did you find out?
ChangT
Oct 22, 2009 10:49 AM
get RIGHT
Aug 22, 2007 08:05 PM
jayare05
Sep 1, 2005 08:24 PM
