Map Sensor blockoff plate
Old May 27, 2007 | 05:26 PM
kornerk12's Avatar
Default Map Sensor blockoff plate
What is the advantage of this ?
Old May 27, 2007 | 05:31 PM
mgags7's Avatar
I'm not sure what the advantage could be.
But it sounds equal to jamming a large rod up your *** and twisting.
The map sensor is like the spinal cord of your ecu....lol why the hell would you block it off, and if you did, you wouldn't need a plate....lol
The only time when you might not want a map sensor is with itbs.....keyword might
Old May 27, 2007 | 05:37 PM
Hawkze_2.3's Avatar
Default Re: Map Sensor blockoff plate (kornerk12)
I guess it covers up the hole if you had to move your MAP sensor or you're stupid enough to get rid of it.
Old May 27, 2007 | 05:38 PM
mgags7's Avatar
A screw and some rtv would take care of that....lol
Old May 27, 2007 | 05:53 PM
kornerk12's Avatar
Default Re: (mgags7)
http://www.roskoracing.com/
please dont talk like that if you are not educated in that particular matter. Go under products there is a description on the product but i dont understand exactly what it is used for.
Old May 27, 2007 | 06:01 PM
sivikvtec's Avatar
Default Re: (kornerk12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by www.RoskoRacing.com &raquo;</TD></TR><TR><TD CLASS="quote">These come in handy when you have switched to an OBD2 throttle body a or aftermarket and you want to keep your MAP sensor in its stock location. </TD></TR></TABLE>
all you had to do was click the link and read the caption.
seriously guys
Old May 27, 2007 | 06:03 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by that site &raquo;</TD></TR><TR><TD CLASS="quote"> Billet aluminum MAP Sensor blockoff plate for OBD2 Honda throttle bodies. These come in handy when you have switched to an OBD2 throttle body a or aftermarket and you want to keep your MAP sensor in its stock location. Comes with blockoff plate, new o-ring and two stainless screws</TD></TR></TABLE>
Couldn't be much clearer than that honestly...you want to block off the MAP, then buy the plate.
Old May 27, 2007 | 06:14 PM
kornerk12's Avatar
Default Re: (Hawkze_2.3)
well like you said why would u want to block it off ?
Billet aluminum MAP Sensor blockoff plate for OBD2 Honda throttle bodies. These come in handy when you have switched to an OBD2 throttle body a or aftermarket and you want to keep your MAP sensor in its stock location. Comes with blockoff plate, new o-ring and two stainless screws.
Old May 27, 2007 | 07:17 PM
sivikvtec's Avatar
because newer hondas have the MAP on the throttle body, and older hondas have it bolted to the firewall attached with a vacuum line. For example, if you installed an integra type-R throttle body on an accord euro-R intake manifold in a 4th gen prelude. You now have 2 map sensor locations, one on the throttle body and the other on the firewal. If for whatever reason, you want to keep the one on the firewall, simply block off the one on the throttle body.
Old May 27, 2007 | 08:20 PM
THC07's Avatar
Default Re: (sivikvtec)
lots of ppl use different map sensors for there turbos, like a GM 3mbar. relocating the GM sensor would require that TB hole to be plugged.
Old May 28, 2007 | 06:29 AM
92_VTEC_lude's Avatar
is it OK to leave the map sensor on the TB in its spot? or it has to be removed and block the hole?
that what I see on my TB (H22a swap) as well with no wire connected to it... I am using the map sensor on the firewall right now...
Old May 29, 2007 | 05:26 PM
Rosko's Avatar
Default Re: (92_VTEC_lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92_VTEC_lude &raquo;</TD></TR><TR><TD CLASS="quote">is it OK to leave the map sensor on the TB in its spot? or it has to be removed and block the hole?
that what I see on my TB (H22a swap) as well with no wire connected to it... I am using the map sensor on the firewall right now...</TD></TR></TABLE>
thats fine to leave it there and unplugged. the blockoff isn't to be used to completely get rid of a map sensor, just allows an obd2 throttle body to be used on an obd1 car without relocating the map from the firewall or buying a new map sensor for the throttle body.
or like someone else said if you've upgraded to a gm map sensor than this can be used to plug the hole or just clean it up a bit.
kpowerdhatch
Oct 20, 2007 02:43 PM
Tyler Con
Oct 10, 2007 11:53 PM
zman
Jun 15, 2006 07:40 PM
88 rex
Aug 4, 2005 04:58 PM
hatchinprogress
Nov 23, 2004 08:21 PM
