questions
correct me if i'm wrong, but i just got off the phone with a guy from hmotors, he claims the exhaust header doesnt bolt directly to the h23 downpipe/cat..but i've heard otherwise on here from previous searches that it does indeed bolt up (h22 header to h23 down pipe) someone set me straight on this issue please i need to know, also should i run a p28 ecu over a p13?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by relited »</TD></TR><TR><TD CLASS="quote">correct me if i'm wrong, but i just got off the phone with a guy from hmotors, he claims the exhaust header doesnt bolt directly to the h23 downpipe/cat..but i've heard otherwise on here from previous searches that it does indeed bolt up (h22 header to h23 down pipe) someone set me straight on this issue please i need to know, also should i run a p28 ecu over a p13?</TD></TR></TABLE>
No they do not bolt up. If its not chipped and tuned stick with the p13 ecu
it is chipped and will be tuned by blue92si from sfpoa.net
also, tigerjapanese.com....they are cheaper than hmotors, but do you think its worth it to go TJ instead of HM? i haven't found much feedback about tigerjapanese
