ignition coil question
I was going to swap out my ignition coil into a friend's car to see if his coil was causing his problem. The coil plug wire popped off of his coil with no problem, however, mine seems entirely different. How do I take this wire off?
It doesn't even appear to be the correct wire set, that or its a fairly cheap wire set; previous owner. Pulling on it does nothing and if I pull on it much harder, as InvaderTrax mentioned, it will just rip the wire from the plug.
So the wire won't come out of the green part? If it's not a tight fit the spark will have to jump a gap and that can melt things like plastic and metal
Might be welded in there...
