Draining Radiator
Old May 25, 2007 | 06:20 PM
LukieLuc's Avatar
Default Draining Radiator
Can I drain the radiator by using the drain plug at the bottom of the radi...., and plug it back and fill it back up, and fill up the reservoir? Or do I need to do other steps? thanks
Old May 25, 2007 | 06:28 PM
InvaderTrax's Avatar
That's the quickest and easiest way to drain and fill the radiator, yes, but it won't clear out your whole system. You can open the hole on the block as well and get most of it, but a true coolant flush is the best way to really clean it out. If you've got $75, just about any shop can do it
Old May 25, 2007 | 08:35 PM
typeS's Avatar
Default Re: (InvaderTrax)
help me out if i'm wrong here. you can be ghetto too and take out the thermostat, hook up a radiator pressure tester, open the drain plug on the radiator and pump away at the pressure tester. if you have the money get it flushed though. probably bring your own honda coolant too, i don't like prestone and all that other bs.
Old May 26, 2007 | 06:40 AM
I use Shell just because that's what we have at the shop
Old May 26, 2007 | 06:58 AM
petern101's Avatar
or you can be even more ghetto and open drain plug then top rad cap...
then run a closed system of distill water through the top and turn on the engine and let it run for a minute or two
Halo
Mar 18, 2012 10:15 PM
xXViperXx
May 6, 2010 06:39 AM
darwin1859
Jan 3, 2010 04:47 PM
br'Y'an
Oct 11, 2004 08:08 PM
FD3S
Apr 20, 2003 04:22 PM
