wheel Alignement
Old May 31, 2007 | 12:23 PM
Siegfried's Avatar
Default wheel Alignement
Do you need a wheel alignment after suspensions install ?
I also have another question,
Nor sure but my rear wheels looks like they are a litte like / \
when I install my D2 coilovers, I have to remove the rear upper arm (triangle shape) because the cotter pin was stuck because of rust. Could it make a change in the alignment or camber ?
The car goes straight but I would like to make sure there won' t be any problem.
Old May 31, 2007 | 01:01 PM
NirVTEC's Avatar
Default Re: wheel Alignement (Siegfried)
I always suggest an alignment after ANY suspension work. What I did was buy the 3yr warranty at NTB and now whenever I make a change I get free check/realignments......Cheating the system!
Old May 31, 2007 | 03:39 PM
Yield's Avatar
Yes you should get an alignment although they can only adjust toe, not camber or caster. If you drop your car too low you will have lots of negative camber like that /\. You have to correct camber with something like camber adjustable balljoint kits.
Old May 31, 2007 | 04:29 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: (Yield)
Caster is adjustable...Its always bets to get an alignment after any suspension modifications.
Old May 31, 2007 | 05:24 PM
vinuneuro's Avatar
Default Re: wheel Alignement (:=:NirVTEC:=:)
How much was the 3yr plan at NTB?
Old May 31, 2007 | 05:35 PM
hamadiscool's Avatar
Default Re: wheel Alignement (vinuneuro)
I know that firestone has lifetime alignment for $150 and usually have discounts and stuff which end up costing around a 100 bucks. I think it is a good deal and after I get my suspension done, I will go and get it done .
Old May 31, 2007 | 07:07 PM
InvaderTrax's Avatar
1 year at NTB was $99
Old May 31, 2007 | 07:50 PM
Montx's Avatar
Caster can be adjusted by unbolting the radius rod and adjusting it that way. I wish they had a center with a year or so of free adjustment
Old May 31, 2007 | 08:19 PM
Yield's Avatar
You can mess with caster if you throw washers on there but that's another modification - it's not factory adjustable.
Old Jun 1, 2007 | 05:48 AM
bboixtc's Avatar
Default Re: (Yield)
I've heard that 3rd gen's 4ws require a special tool for an alignment. I have a 4th gen 4ws, is there anything special that needs to be done?
Old Jun 1, 2007 | 05:50 AM
Montx's Avatar
you don't * HAVE * to, but it makes it TONS easier for the alignment center. IF, IF, you get lucky and go to an alignment center that actually cares about it's business, they'll do it like mine - align the back tires then align the front tires. Then, after that, align them again to ensure they're straight.
Or, if you are nice, you can provide them with a locking pin since most/if-not-all alignment centers won't have one.
Old Jun 1, 2007 | 06:30 AM
bboixtc's Avatar
Default Re: (Montx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Montx &raquo;</TD></TR><TR><TD CLASS="quote">you don't * HAVE * to, but it makes it TONS easier for the alignment center. IF, IF, you get lucky and go to an alignment center that actually cares about it's business, they'll do it like mine - align the back tires then align the front tires. Then, after that, align them again to ensure they're straight.
Or, if you are nice, you can provide them with a locking pin since most/if-not-all alignment centers won't have one.</TD></TR></TABLE>
what you said what a little indirect. I have a 4th gen 4ws not a 3rd gen. I'm asking because the 4th gen is electronic 4ws and the 3rd gen's are mechanical.
Old Jun 1, 2007 | 06:42 AM
Montx's Avatar
Oops, I didn't read that it was for the fourth gen. My bad - I dont know then.
nirvana_1959
Apr 1, 2011 10:32 PM
corkss
Suspension & Brakes
Dec 2, 2008 11:30 AM
frankcougar
May 11, 2007 09:55 AM
TypeR II
Suspension & Brakes
Jun 3, 2005 02:21 PM
Boost2NA
Nov 13, 2004 03:10 PM
