H22A idles on start up for a few seconds then shuts off!!!! HELP!!
i have a 96 honda accord LX with a jdm h22a and for some reason when i start up the motor it would idle high then slowly go down but when it goes down it goes down all the way which causes it to shut off... ive been search for help but i haven't heard n e information yet.. hopeeing u guys can help me out !!!!!!
Re: H22A idles on start up for a few seconds then shuts off!!!! HELP!! (preludefien)
i threw it in and i just drove it. it drove fine til now its still the same CEL lights same everything but i have a feeling i might need a major tune up but im not sure i havent changed n e thing ever sense i got the mottor the only thing ive changed was the spark plugs. but i also have a loose spark plug wire im still getting the connection but then its not like the other ones were it would clip on to the spark plug. do u guys think i need to get new wires?. the one i have on there now are the nology hot wires.i was running a p28 chiped but then it was still doing the same thing so i switched back to the jdm p13 ecu
Re: H22A idles on start up for a few seconds then shuts off!!!! HELP!! (duceducecord)
What does the check engine light read?
Address the obvious stuff first then worry about chaning the other stuff.
If you crack the throttle open does it still run or is it only an idling issue?
Re: H22A idles on start up for a few seconds then shuts off!!!! HELP!! (PirateMcFred)
the codes are prim 02, EGR circuit, and tracktion control which i dont have, the car is driveable but im just trying to get the idle issue fixed
The O2 will help with mileage and driving in general fix that at elast then see if your idle improves.
