A/C Removal Question.
Old May 29, 2007 | 01:10 PM
Depeche's Avatar
Default A/C Removal Question.
Can anyone link a walkthrough on A/C removal on a 4th gen h23. I searched and didnt have much luck. If noone knows of a walkthrough my main question is what i do about the belt that runs with the alternator. It looks as if i remove it that it will have some adverse affects
Old May 29, 2007 | 01:18 PM
bb_one's Avatar
Default Re: A/C Removal Question. (Depeche)
It is pretty straight foward. Where ever there is an AC component, just take it off. Compressor, AC lines, dryer, receiver, condensor. evap core, heater core, and blower if you want to completely rid the HVAC system.
As for the belt, just measure the length of belt you need for the crank pulley to the alternator and give that meaurement to NAPA and they should be able to find a belt for you.
Old May 29, 2007 | 07:04 PM
RAB's Avatar
RAB
Default Re: A/C Removal Question. (bb_one)
Just unbolt and remove everything.
Old May 29, 2007 | 07:07 PM
kulrevon's Avatar
Default Re: A/C Removal Question. (RAB)
The interior a/c components are a little hard to get to. But you the compressor, condensor, lines and mounts have some weight to them and can be removed easily.
Old May 29, 2007 | 07:28 PM
saikou's Avatar
Default Re: A/C Removal Question. (kulrevon)
Ask for a 1992 Prelude S alternator belt without A/C, to make it easy.
Old May 30, 2007 | 05:40 AM
Silver Surfer's Avatar
Default Re: A/C Removal Question. (saikou)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saikou &raquo;</TD></TR><TR><TD CLASS="quote">Ask for a 1992 Prelude S alternator belt without A/C, to make it easy.</TD></TR></TABLE>
have you actually done this?
BECAUSE IT DOES NOT WORK.......it's the wrong lenght and even worse the wrong number of ribs......stop posting **** you don't know about, every time this thread comes up I have to repeat myself because people can't search and other people spread wrong-information.
you need a 37" 6-rib belt
maybe we need a tutorial on how to use the search button
https://honda-tech.com/zerothread?id=1792042
https://honda-tech.com/zerothread?id=1796438
Old May 30, 2007 | 09:56 AM
M@'s Avatar
M@
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon &raquo;</TD></TR><TR><TD CLASS="quote">The interior a/c components are a little hard to get to. But you the compressor, condensor, lines and mounts have some weight to them and can be removed easily.</TD></TR></TABLE> x2
I just removed and replaced the compressor and reciever in about 3 hours.
Old May 30, 2007 | 10:32 AM
Prudz_lude's Avatar
Default Re: A/C Removal Question. (M@)
what about that one hose. I cant get it off. Does i have to take out my dash to get to this one out?
Old May 30, 2007 | 10:53 AM
Prudz_lude's Avatar
Default Re: A/C Removal Question. (Prudz_lude)
Ok so i was looking in the helms manual and it looks like there is on bolt i have to undo and it should just pop off. Correct? sorry about the small high jack but i think this is completely relevant to a/c removal.
Old May 30, 2007 | 11:57 AM
saikou's Avatar
Default Re: A/C Removal Question. (Silver Surfer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silver Surfer &raquo;</TD></TR><TR><TD CLASS="quote">have you actually done this?
https://honda-tech.com/zerothread?id=1796438</TD></TR></TABLE>
The OP has an H23 moron. 5 rib pulley on an H23 alternator pulley & 6 rib pulley on an H22 alternator pulley. Maybe YOU should stop spreading wrong-information.
Edit:
And to answer your question, I did ask for an alternator belt for a 1992 Prelude S without A/C. Worked like a charm, asshat.
Edit 2:
And to prove you're a dumbass, here is my OWN alternator belt:
Again, dumbass.
Modified by saikou at 2:25 PM 5/30/2007
Old May 30, 2007 | 12:07 PM
bb_one's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prudz_lude &raquo;</TD></TR><TR><TD CLASS="quote">Ok so i was looking in the helms manual and it looks like there is on bolt i have to undo and it should just pop off. Correct? sorry about the small high jack but i think this is completely relevant to a/c removal.</TD></TR></TABLE>
Yes, there is a 10mm nut that holds that line to the evap core lines (near the ABS modulator). Once you remove the nut, it should pop off.
Old May 30, 2007 | 01:45 PM
Prudz_lude's Avatar
thanks. I was worried i would have to take apart the dash, or worse, get lazy and cut the line off with a saw lol
Roadmister
Jul 22, 2011 11:53 PM
stretchd1
Feb 18, 2008 08:41 AM
turbociv910
Jan 25, 2007 07:01 PM
preludebbduce
Sep 9, 2006 11:35 AM
RemoveGiantWingOnYourCar
May 5, 2006 08:40 AM
