quick dizzy question
Old May 25, 2007 | 11:34 AM
DarkBB4's Avatar
Default quick dizzy question
i'm gettin my car towed to a shop, and yesterday while swapping distributors.. somehow my friends BROKE off into my head... ( i found the little teeth luckily)... therefore i had to let him borrow my distributor
Can i use a h23 distributor on my jdm h22a? (are they internal or external coil?)
EDIT: i just got it, and its an internal coil... my h22a1 has a external coil wiring.. and now i have to convert... how do i convert it?
Modified by DarkBB4 at 1:13 PM 5/25/2007
Old May 25, 2007 | 12:37 PM
AndyD's Avatar
Default Re: quick dizzy question (DarkBB4)
I'm not following what you are asking. Did you find a JDM replacement distributor?
If you are have an H23 distributor, use that. Yes, the H22 and H23 distributors are the same.
Modified by AndyD at 4:48 PM 5/25/2007
Old May 25, 2007 | 01:08 PM
DarkBB4's Avatar
Default Re: quick dizzy question (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">I'm not following what you are asking. Did you find a JDM replacement distributor?
Modified by AndyD at 4:48 PM 5/25/2007</TD></TR></TABLE>
ahh sorry....
The replacement distributor i received is an internal coil... and my car is setup for an external coil setup...
can i use this distributor somehow?
Old May 25, 2007 | 05:11 PM
EvstarH22's Avatar
Dude a jdm h22a has an internal coil....hense it being annoying when your dizzy goes. Secondly the change between internal and external is easy, just look for some directions anywhere on the web its pretty much just one wire. I used to have an internal on my jdm but changed it over with a distributor king dizzy, (only 150 bucks w some upgrades) and then got a msd blaster ss coil and tada! MUCH better spark.
civic919900
Jul 31, 2007 10:25 AM
tonezilla
Jan 31, 2004 12:16 PM
tonezilla
Jan 24, 2004 04:24 PM
dflipmode
Jan 18, 2003 11:42 PM
