Problems with 01 prelude. Help!
Old Jul 18, 2009 | 04:14 PM
01blklude's Avatar
New User
Default Problems with 01 prelude. Help!
I have a 2001 Honda Prelude non SH model.
I had a misfire a couple of weeks ago and changed the spark plugs the original owner had put in. He put in autolites, so I switched them out to NGK's.
The car ran great for the past couple of weeks.
I went to start my car in the morning and noticing the RPM's bouncing. Check engine light was on. Idle air control malfunction. Is my IAC bad? I tried cleaning it but that didnt help.
I also have a misfire on 1 and 3 too.
Any help is appreciated.
Old Jul 20, 2009 | 05:04 PM
fraserboostedh22's Avatar
Default Re: Problems with 01 prelude. Help!
try changing out the plug wires. if u haven't already. it fixed my problem.
Old Jul 21, 2009 | 04:47 PM
01blklude's Avatar
New User
i haven't yet but ill give that a try.
Old Jul 21, 2009 | 10:56 PM
Papasmurf2k3's Avatar
+1
Also check your cap and rotor
Old Jul 23, 2009 | 04:10 PM
01blklude's Avatar
New User
i did that and its still doing the rev bouncing and the occasional misfire could it possibly be something in the distributor like maybe the ignition control module?
Old Jul 23, 2009 | 06:05 PM
yeah, that is always a possibility... In my experiences, when an ignition control module goes out, you just don't get any spark at all, not an occasional misfire...
Old Jul 23, 2009 | 08:38 PM
yeah, i forget to mention about that. I had that problem with a MR2, i changed that out and it runs perfect. but the MR2's not in the distributor. I think on the 5th Gen lude is in the distributor. you probably have to replace it.
J.R
Dec 12, 2014 08:29 AM
carbonemt
Aug 30, 2011 08:51 PM
Toroke
Jun 30, 2008 08:29 PM
si93lude
Jul 22, 2002 12:29 PM
