install manual fan switch
Re: install manual fan switch
which fan? I am assuming the one controlled by the thermo sensor... you could either wire it into a relay using the switch OR wire a switch to the sensor on your thermostat that turns it on or off... give us more info please- is your fan working? is it oem?
If its a stock setup, all you have to do is splice into the green wire at the fan thermoswitch on the t-stat housing, run the wire into the cabin to a simple switch and then to ground. No relay needed.
yes, is the fan control by the thermo sensor. they are aftermarket and slim. they are working fine. but my lude turbo and it always want to overheat when i m climbing uphill (even small hill). some one told me to try to manually to turn on the fans to see if that helps. my compression was good. no leaks, everything works. just got frustrated with that problem. now willing to try anything. thks much for reply!!
thks. so is the green wire ground? would the fan turn on without the motor runnings. thks again
ground the green wire..
fans wont turn on when the car is off
i wired mine to my cruise control button
even the little light on the cruise control button turns on when i press the button to turn my fans on
thks man. i was thinking about the cc button too. bcause i have no use for it anyways.
My cooling fan runs constant, I've had it that way for several years now. I have a 12" Hayden slim fan. No excess power draw, no problems, nothing. Lifetime warranty on the fan. My A/C fan is still wired to the switch however.
sorry, just wanna ask 1 more question. which wire from the cruise control unit should i wire to? can't figure out which one by looking at it. TIA
thks for the reply. would the car warm up ok? i heard people said that is kind of hard for the car to warm up.
Make sure you get a proper switch. I had one in the car I bought and the wire melted at the switch while I was driving. I saw a puff of smoke and it stopped working. It could have started a fire.
i needed to install a relay when i used my CC button
the CC button sends out a 12v signal when pressed and the fan needed a ground
i hooked up the relay to ground the connection when the button was pressed
you can prolly get away without using the relay....but then your cool little green light on the CC button wont work when you press the button
So I got mine cooling fan connected to my CC but my CC light just went out so now my fan don't work ?! So is there a fuse or some type of relay I need to replace y'all think 💭? Lmk if anybody can help would really appreciate it?
VTECAcuraGSR
12
03-01-2004 11:11 AM
