12v on the engine block when starting? Help!
Old Jul 13, 2009 | 06:05 PM
92hondalude's Avatar
Default 12v on the engine block when starting? Help!
Okay heres the deal. When everything is acc everything is fine, but when you try to start the car the starter clicks and the engine block has 12v. If we keep trying to start it and something metal is touching any ground it gets red hot. But sometimes the car starts. We have tryed swaping starters and the starter relay. The battery is reloacted to the trunk and the under hood fuse box is inside the car now. The only thing we can think of is the remote wire for the starter is grounding out somewhere but where does that wire run?
Old Jul 13, 2009 | 06:24 PM
92civlude's Avatar
Default Re: 12v on the engine block when starting? Help!
Starter is shorted internally. Bench test under the same conditions to verify.
Old Jul 13, 2009 | 06:35 PM
but we switched starters from my beater and they both work on the beater.
Old Jul 13, 2009 | 06:38 PM
92civlude's Avatar
OK. What about the ground side? Do you have a GOOD SOLID ground from the motor to the battery? Have you tried disconnecting the solenoid wire at the starter and then cranking the key to see if the solenoid wire is the problem? I think if the solenoid wire was shorted, It would melt the ignition switch and kill the starter relay.
Old Jul 13, 2009 | 09:26 PM
allentownrep's Avatar
Try Grounding the Tranny...something similar like this happened to me when i relocated my battery to the back...I grounded the tranny and it fired right up
Old Jul 14, 2009 | 03:39 PM
OMG thanks everyone. I cleaned up the tranny ground and added an extra ground and she fired right up and 0v on the block!
Old Jul 14, 2009 | 08:29 PM
2x0
Apr 29, 2018 09:35 AM
LsScivic
Mar 4, 2009 07:39 PM
91crxz280
Jan 3, 2009 11:56 PM
TravisB16a
12
May 16, 2008 04:26 PM
curtis318b16
Jul 17, 2007 07:37 AM
