Grounding Wire
Old Mar 11, 2010 | 09:06 AM
nonpareil's Avatar
Default Grounding Wire
I was working on my car yesterday replacing some grounding wires when I noticed the main cable from the negative terminal on the battery, goes straight down but then its cutt off and not attached to anything. Does anyone know where this wire is supposed to be attatched?
I know of 2 grounds on the car right now, battery to chassis
Engine to Chassis
am I missing one?
Old Mar 11, 2010 | 09:13 AM
fasthatch95's Avatar
Default Re: Grounding Wire
should just be those 2
Old Mar 11, 2010 | 09:55 PM
customcivic93's Avatar
doesnt matter where u run that ground to as long its grounded good to a bare spot of metal which means sand the paint off where ur going to mount that ground to
Old Mar 12, 2010 | 12:34 AM
nonpareil's Avatar
Okay perfect thank you.
I do have another ground done properly.
I just wasn't sure if another cable needed to run to the tranny
Old Mar 12, 2010 | 02:52 AM
BlackCatt's Avatar
The large ground coming off the negative terminal connects to the tranny on my lude.
It also has a smaller cable which attachs to the chassis.
Old Mar 12, 2010 | 03:22 AM
nonpareil's Avatar
The smaller one is the ground I replaced.
Any chance you'd be able to provide me with a picture of where and how it connects on the tranny
Old Mar 12, 2010 | 04:58 AM
darkestfenix's Avatar
dont mind the red circles. I just did that for a friend, last time I had to explain him something.
phatnucca
Apr 5, 2012 10:42 AM
acmoc
Jan 19, 2011 07:49 AM
jizzer671
Dec 9, 2006 08:09 PM
keepitngga1
Sep 22, 2006 02:05 AM
S13Koop
Aug 12, 2001 04:21 PM
