93 clutch problems
My 93 prelude vtec is having clutch problems. the clutch will not engage. i can drive down the road and push the clutch in it does nothing. but if i push the clutch in and hit the gas the car just revs up like the clutch is working but then just drops back into gear. the clutch pedal feels normal and ive bled the slave cylinder but it didnt help. can anyone help me?
here is a test to see if the clutch is bad turn on your car press the clutch pedal down put it in first gear let off the clutch and let the car stall and if it stalls right away with no problem then its good if it takes a while to stall the clutch is slipping.
