Timing Belt walking off.
Old 02-25-2010, 10:53 PM
rpaul's Avatar
Default Timing Belt walking off.
Can anyone Tell me how my timing belt is walking off my cam gears, and rubbing my valve cover??
rpaul is offline
Old 02-26-2010, 07:31 AM
Default Re: Timing Belt walking off.
Not enough belt tension.
minilogoguy18 is offline
Old 02-26-2010, 07:53 AM
PirateMcFred's Avatar
It's not a tension issue if you've got the auto-tensioner. The belt coming off is typically an issue with #19 being bent and it puts the tensioner bearing out of alignment. It's easy to bend it when torquing the 12mm on the end.
PirateMcFred is offline
Old 02-26-2010, 12:27 PM
rpaul's Avatar
thanks for the input, do i need to change just the bolt or the bearing also.
THANKS ALOT MUCH APPRECIATED.
rpaul is offline
Old 02-28-2010, 06:32 AM
ekcoupeh22's Avatar
isnt there also 2 alignment shims on the crank that help hold into place? are you missing one?
ekcoupeh22 is offline
Old 03-05-2010, 09:16 AM
Moderator
snobordboy's Avatar
Hopefully a dumb question, but if you removed your balance shaft belt, do you still have the pulley on the crank for it? Once when I was in a rush I forgot to replace mine, and the belt walked out quickly. Luckily I caught it while the car was still on stands.
snobordboy is offline
Old 03-09-2010, 09:14 AM
TRIAL USER
BUMP. i have the same problem as the OP, but this thread kinda died.. does anyone have a solution?
edlude is offline
Old 03-09-2010, 09:25 AM
Pirate already posted how to fix it.
Old 03-09-2010, 09:51 AM
Start at the top of this thread and read. Or search:
https://honda-tech.com/forums/showth...hlight=walking
Old 03-09-2010, 12:26 PM
BB1 H22A LUDE's Avatar
Say PirateMcFred and anyone else who can help, I sent my prelude (1992, H22A) in for it's timing belt at a Honda dealer, all good and well. 10k Km's later I decided to fix up the LMA's which were shot, but my timing belt wouldn't release tension nor could I get the adjusting nut (#34 in your diagram) to undo! And for the record my belt also runs off the cams, I leave the upper cover off so I can keep a watch full eye on it, i don't trust the current setup!!!
I tried everything but this bolt would not undo (i used a plumbing wrench which has digged into the bolt but still no luck!). Honda obviously messed something up (over torqued, bent or lock tight). They also neglected to put on #12 (the spring), which is causing that #13 plate to vibrate/make vibration sounds at 1.5k rpm. Is that spring crucial?
What can I do to fix this up? I can't lift the engine out myself, plus I need the car to get me to work etc and Honda wouldn't accept any responsibility, but I could pay them to get it fixed.... Guess breaking/snapping the bolt off is my only hope? I have attached some pics and there it is obvious that the bolt withstood a large amount of torque!
Last image is the bolt that is suppose to release some tension so I can get the timing belt of the cams, but no such luck.
BB1 H22A LUDE is offline
Old 03-09-2010, 04:15 PM
autoluder's Avatar
try heat
autoluder is offline
Old 03-10-2010, 03:20 AM
flyrod's Avatar
Take it back to the stealership and tell them to fix their mess.
flyrod is offline
Old 03-10-2010, 05:34 PM
Heat could work, don't know how much more "handling" the bolt can take though. I would take it back to the dealership but to be honest I cant trust them now. It's not that hard to tighten a nut to 45nm and to put a spring back that fell off/got taken off, not sure how they messed that up!
I can see it being even worse if the car goes back, the guy who created the mess will be blamed, and he will have to fix it. The blame will lead to anger, which will be taken out on the car he is working on, hence more problems later.
Ideally I need to get it loose but I don't think it will. If I snap the nut off, surely I can then relieve the timing belt/balancer belt tension, then un-bolt the tensioner pulleys bolt from the block to allow me to thread in a new bolt to set the tensioner etc on?
Old 03-11-2010, 09:46 AM
Moderator
snobordboy's Avatar
In the end, yes, that is an option.
And that spring, is only there to provide the tension when adjusting the belt, otherwise that arm should be locked in place.
Old 03-11-2010, 10:26 AM
That's not correct. That plate/arm (#13) floats all the time. The spring is required to keep it from rattling. It is not necessary to have #13 at all IMO.
Old 03-11-2010, 10:35 AM
^ #13 definitely makes a vibration/rattle sound at this point and the plate, although fixed, it can move a small amount. Well guess Ill be trying heat to get it undone and if all else fails Ill snap off that nut, my LMA are truly "lost-motion" assemblies now....
Old 03-16-2010, 12:01 PM
rpaul's Avatar
Yep it was a dumb question, its been a year since i last had this car going so.... it's working good now, thanks everyone for all your help.
rpaul is offline
91 b20 integra
09-22-2014 08:44 AM
thegatekeeper14
08-05-2009 03:28 PM
omgwtfbbqcrx
02-16-2006 09:38 PM
jvonb
12-18-2005 07:47 AM
1SlowSi
02-06-2005 04:39 PM
Quick Reply: Timing Belt walking off.
  • Ask a Question
Question Title:
Description:
