help remove ac
Old Mar 10, 2010 | 06:21 PM
toukao35's Avatar
Icon6 help remove ac
I looked in the faq and didn't find a link where it showed how to remove the ac unit. Does anyone know how to? Or knows a link with pictures?
Old Mar 10, 2010 | 07:02 PM
5SpdH22's Avatar
something gnarly
Active Streak: 30 Days
Default Re: help remove ac
1. Get the system evacuated.
2. Loosen the belt on the compressor, or cut it. You'll need a new one either way.
3. Unbolt compressor, all lines (one high pressure, one low), condenser (looks like a small radiator), etc.
4. Remove evap from under dash. (all screw locations are pointed out in the manual)
5. Measure around the crank pulley and alternator pulley with a string, and buy a new belt that will fit.
I think that's about it. It's extremely self explanatory when you look at it.. can't really screw it up. Just post up before you remove anything you're not completely sure about.
Old Mar 10, 2010 | 07:31 PM
MikeLuder's Avatar
I would just like to add, try driving in the rain with out AC. Does anyone know how to keep your windows from completly fogging with out it? Because I sure as hell can't figure it out.
Old Mar 11, 2010 | 01:48 AM
BlackCatt's Avatar
^ yeah i had that problem for a while when my a/c was stuffed. The only solution
i found was to keep the drivers window down a bit, which is f%&ked cause then
some rain comes inside, but it definately helped. Couple of times i still had to
wipe the windscreen inside with a cloth.
OP: as for the a/c removal, follow the steps above and just take your time and
slowly remove each part of the system being careful not to remove anything
which is not part of the a/c.
Old Mar 11, 2010 | 05:08 AM
MikeLuder's Avatar
There has to be a way, earlier civics didn't have AC and they don't fog as bad using the defrost function. I know the AC dryer filters the moisture in the air, but am I missing something?
ahenscheid
Jan 28, 2012 08:30 PM
stretchd1
Feb 18, 2008 08:41 AM
RemoveGiantWingOnYourCar
Aug 3, 2005 09:06 AM
Etylorcen
Jul 27, 2002 07:23 PM
