ITB'S ON H22 TURBO ?
Old 02-25-2010, 04:49 AM
Default ITB'S ON H22 TURBO ?
IS THIS A GOOD IDEA AND WHAT ARE THE GOODS AND BADS ABOUT THIS SET UP ?
MODS:
AEBS SLEEVED H22A1
89MM BORE
WISECO PISTONS
SKUNK2 SPRINGS AND RETAINERS
STOCK CAMS
BALANCED BOTTEM END
I WAS JUST WONDERING IF THIS WAS A GOOD IDEA BECAUSE I WANTED TO DO THIS BUT I HAVE NEVER SEEN IT.
#1rudebwoy is offline
Old 02-25-2010, 05:11 AM
Default Re: ITB'S ON H22 TURBO ?
bump
Old 02-25-2010, 06:01 AM
25 veiws and nothing
Old 02-25-2010, 06:18 AM
kornkid21792's Avatar
if you couldn set it up right and get it tuned properly itd give u a good advantage
kornkid21792 is offline
Old 02-25-2010, 06:35 AM
Working
-RedneckDave-'s Avatar
Are you just looking to see if ITB's have been utilized with a turbo setup? If so, the answer is yes and it has been done many times. i.e. Nissan r33 r34, HPF M3's, Audi 5cyls, etc. I want to say that user TonytheTiger had ITB's on his Turbo integra some time back as well. When you build the plenum to sit on top of the ITB's, some care should be taken to ensure equal flow for each runner. You could go with a dual plenum similar to Audi employed, or a tapered single plenum. It all comes down to what you want. If you just want to do this for the bling factor, I don't know if it is worth the trouble.
-RedneckDave- is offline
lowacc97
01-09-2012 02:47 PM
virgstyle
21
08-08-2006 02:21 AM
93h22a1vtec
12-20-2005 11:40 AM
rhemu1
07-22-2005 06:15 AM
HyperFlow
07-24-2003 01:57 PM
Quick Reply: ITB'S ON H22 TURBO ?
  • Ask a Question
Question Title:
Description:
