Fixing syncros?
Old Oct 14, 2003 | 03:38 PM
stRodda's Avatar
Default Fixing syncros?
im assuming thats the problem. it only happenns going from 4th to 5th. but if im shifting and the rpm's are above 3k i get a little vibration like its about to grind. but when i shift after redlining 4th i get a bad grinding sound. i havent done anything out of the ordinary and it just started this morning.
whatever it is, how much woud it cost to fix? and if i shift slower so the rpms get a chance to drop and it doesnt grind... will that keep it from getting worse? also, what can cause this to happen?
Old Oct 14, 2003 | 04:48 PM
silver97prelude's Avatar
Default Re: Fixing syncros? (stRodda)
all you have to do is change to GM syncromesh trans fluid, the grinding will stop.
Old Oct 14, 2003 | 05:58 PM
stRodda's Avatar
Default Re: Fixing syncros? (silver97prelude)
sounds easy and cheap, i hope ity works well.
thanks a lot.
btw, will any autoshop have it?
Old Oct 14, 2003 | 06:24 PM
piotrush's Avatar
I think only GM dealers carry it
PrecisionH23a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silver97prelude &raquo;</TD></TR><TR><TD CLASS="quote">all you have to do is change to GM syncromesh trans fluid, the grinding will stop.</TD></TR></TABLE>
Not a bad idea, but keep in mind it is not a permanant solution to your problem. Just a temporary one. More then likely, you will need to replace your synchro's as the grinding becomes more severe. I recommend replacing ALL the synchro's while your tranny is out.
Old Oct 14, 2003 | 06:25 PM
caLiH22A's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stRodda &raquo;</TD></TR><TR><TD CLASS="quote">sounds easy and cheap, i hope ity works well.
thanks a lot.
btw, will any autoshop have it?</TD></TR></TABLE>
No, you're going to have to go to General Motors(GM) dealer to get it, they should have it in the parts deparment. Also there are two different kinds of GM synchromesh, get the regular one.
Old Oct 14, 2003 | 07:29 PM
LudeyKrus's Avatar
I remember seein a guy in the teg forum, i think, that did a VERY good write up on swapping out the main-shaft on his tranny when it got stripped by a flywheel....he also mentioned how to swap out syncros!
Old Oct 14, 2003 | 07:49 PM
Gennady's Avatar
New User
Where does one get all the parts to rebuild a tranny ie synchros.
Old Oct 14, 2003 | 08:39 PM
stRodda's Avatar
Default Re: Fixing syncros? (caLiH22A)
i was reading around the teg forum. i didnt find the how-to, but i saw a talk about which fluid to get... either regular or friction modified. i saw a few opinions, but does anyone know for sure which i should get. and if it matters i have lsd(phantom grip).
also, how long will it take before it gets worse? and what can cause this to start? did i do something or is it just a random occurance?
Modified by stRodda at 9:58 PM 10/14/2003
Old Oct 15, 2003 | 05:40 AM
Sephro's Avatar
Default Re: Fixing syncros? (GudeH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a &raquo;</TD></TR><TR><TD CLASS="quote">
Not a bad idea, but keep in mind it is not a permanant solution to your problem. Just a temporary one.</TD></TR></TABLE>
Yes this is true but I had the same thing grind going into 5th. Put in the Synchromesh and have driven about 20k miles or so with no grind at all. So I also recommend it. the $30 you are going to spend is well worth it even if it is just buying you time.
Old Nov 8, 2003 | 06:04 PM
crxhybrid1320's Avatar
Default Re: Fixing syncros? (Sephro)
Well Im putting a rebuilt transmission into my race car. Should I put the honda MTF fluid in it. Or shoud i just always use the syncromesh from the beginning to the end. Or just put it in when it startes to grind.
Old Nov 8, 2003 | 06:12 PM
PhatboyNYC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stRodda &raquo;</TD></TR><TR><TD CLASS="quote">im assuming thats the problem. it only happenns going from 4th to 5th. but if im shifting and the rpm's are above 3k i get a little vibration like its about to grind. but when i shift after redlining 4th i get a bad grinding sound. i havent done anything out of the ordinary and it just started this morning.
whatever it is, how much woud it cost to fix? and if i shift slower so the rpms get a chance to drop and it doesnt grind... will that keep it from getting worse? also, what can cause this to happen? </TD></TR></TABLE>
I had the same problem on my 93 Prelude VTEC and just put in GM Synchromesh tranny fluid (the regular one and not friction modified) today and it lived up to the hype. The car shifts much smoother now into each gear and my 5th gear grind disappeared.
Old Nov 8, 2003 | 07:26 PM
user 9782082308's Avatar
Default Re: Fixing syncros? (PhAtBoY Si)
I think we need to mass email the bastards at Level 10. They were supposed to come out with a manual rebuild kit 2 years ago! The Syncro mesh will help you get by for a while but you'll need to rebuild. And hope Hondas selling the syncs by themselves cause they go back and fourth from that and you having to buy the entire gear set to get them.
*Call out to the aftermarket* We need some tranny internals too!!!
Old Nov 9, 2003 | 06:49 AM
fastludeh22's Avatar
Default Re: Fixing syncros? (crxhybrid1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxhybrid1320 &raquo;</TD></TR><TR><TD CLASS="quote">Well Im putting a rebuilt transmission into my race car. Should I put the honda MTF fluid in it. Or shoud i just always use the syncromesh from the beginning to the end. Or just put it in when it startes to grind.
Old Nov 9, 2003 | 10:34 AM
LudeyKrus's Avatar
I would run Syncromesh from the start; it really can't hurt anything.
Old Nov 9, 2003 | 12:16 PM
SKDRCR's Avatar
Default Re: (LudeyKrus)
i have the gm synchromesh in mine and it still
grinds into fifth if i'm high in the rpm band in fourth
i guess my synchro is worse than most of your's
so if i'm at the top of fourth, i either let it slide into
fifth or double clutch it
Old Nov 9, 2003 | 12:27 PM
spoolinlude's Avatar
I live under a rock
Default Re: (Wont be beat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wont be beat &raquo;</TD></TR><TR><TD CLASS="quote">Where does one get all the parts to rebuild a tranny ie synchros.</TD></TR></TABLE>
old trannies or pay out the ying yang at the dealer
Old Nov 9, 2003 | 01:56 PM
Alright Thanks
Old Nov 9, 2003 | 09:53 PM
Gerhard_001's Avatar
Just an FYI on GM synchromesh it is available Autzone's and some auto parts stores. This fluid is produced by Pennzoil and can be had for 'half' the price as the dealer is charging. It is the regular synchromesh not the friction modified crap. It is the yellow Pennzoil packaging that says synchromesh. And yes synchromesh is made by Pennzoil.
Old Nov 10, 2003 | 12:40 AM
bad-monkey's Avatar
Default Re: Fixing syncros? (Gerhard_001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gerhard_001 &raquo;</TD></TR><TR><TD CLASS="quote">Just an FYI on GM synchromesh it is available Autzone's and some auto parts stores. This fluid is produced by Pennzoil and can be had for 'half' the price as the dealer is charging. It is the regular synchromesh not the friction modified crap. It is the yellow Pennzoil packaging that says synchromesh. And yes synchromesh is made by Pennzoil. </TD></TR></TABLE>
Old Nov 10, 2003 | 07:24 AM
LudeyKrus's Avatar
whoa, for real?!
I WAS gonna get some friction modified, but can't turn down a good deal!
Old Nov 10, 2003 | 06:18 PM
Pennzoil is the same thing as the GM Synchromesh or is it similiar to that.
If you go to the parts store and ask for HONDA MTF the parts store will give you 5W-30 oil and its doesnt work the same as the HONDA MTF.
Old Nov 10, 2003 | 06:36 PM
Jeff33S's Avatar
Just courious has any one priced the parts for a basic tranny rebuild I'm gonna have to do one soon, I can do the rebuild, but I've been to lazy to price it yet.... GM syncromesh cant save me now
-Jeff-
Old Nov 10, 2003 | 07:06 PM
Default Re: (Jeff33S)
I have an account with ACURA and its 250 for the 3rd gear set. I dont think they sell them individualy. What gears grind?
Old Nov 10, 2003 | 08:54 PM
Jeff33S's Avatar
Default Re: (crxhybrid1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxhybrid1320 &raquo;</TD></TR><TR><TD CLASS="quote">I have an account with ACURA and its 250 for the 3rd gear set. I dont think they sell them individualy. What gears grind?</TD></TR></TABLE>
Yea I know they sell them in gear sets I just havent priced it yet..... I too have an account with the local honda dealerships through a shop I work at part time... I'll probably do better price wise though to get em from hparts.com or somewhere online.... 2nd is really fubared... and 3rd has seen better days no problems with any others.....
-Jeff-
creator1322
Sep 27, 2008 04:52 PM
r01516
Sep 3, 2008 10:54 PM
tpod
Jan 4, 2007 12:49 AM
RiCE On IcE 2
Jul 26, 2004 04:32 PM
hmongdude
Jul 14, 2003 01:17 PM
