Trouble Code #4 HELP!!!!
Old Oct 13, 2003 | 05:04 PM
Slatelude's Avatar
Default Trouble Code #4 HELP!!!!
As far as I can tell from Chiltons....this is the Crankshaft Position Sensor. Which to the best of my memory is in the distributor, along with the Top Dead Center, and...some other sensor. NEWays, problem is the rotor bug seems to be fused to the distributor shaft and therefore cant get to the CKP sensor. Replaced distributor 2 years ago because old rotor bug broke and inside part was fused to that distributor shaft....anyone else have this problem....ways to keep if from happening/fix it w/out getting a new distributor? Thanks guys...
Old Oct 13, 2003 | 05:23 PM
junbb1's Avatar
Default Re: Trouble Code #4 HELP!!!! (Slatelude)
is it aftermarket, the new dist. is there red dust inside the cap
Old Oct 13, 2003 | 05:26 PM
Slatelude's Avatar
Default Re: Trouble Code #4 HELP!!!! (junbb1)
no red dust.....everything still stock distributor wise '93 H23A
Duffboy
Oct 5, 2015 05:43 PM
raidacaipo
May 18, 2009 08:57 AM
CivicHatchback14
Jul 14, 2004 12:00 PM
staticrex
Jun 9, 2004 12:13 PM
Krayzielix
Feb 11, 2003 10:10 PM
