JDM H22A Problems
Old Oct 14, 2003 | 03:56 PM
nocturnalJDMH22A's Avatar
Default JDM H22A Problems
Have any of you had a problem with the ECU codes not coming on. Like on my car, the Engine light is off, but when I jumpthe wires it comes up code 1. I also a a bunch of other codes but I don't get these codes until I jump the connector. The main reason for this post is that my car is not starting. I have cleared all the code in the ECU but I still get a CODE 36. I had a bad Fuel Pump and got that replaced with a 255 lt / hr WALBRO HP. The car started right up and no problems. This morning, My car would not start at all but it did turn sounded like it would start but it wouldn't. Any help would be great. Thanks
Old Oct 14, 2003 | 06:05 PM
satan_srv's Avatar
Default Re: JDM H22A Problems (nocturnalJDMH22A)
the code 36 is a soft code for traction control no? I think you have the wrong ecu? Or do you need it for the 4ws?
Old Oct 15, 2003 | 05:43 AM
CHK4TIX's Avatar
Default Re: JDM H22A Problems (satan_srv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">the code 36 is a soft code for traction control no? I think you have the wrong ecu? Or do you need it for the 4ws?</TD></TR></TABLE>
yes code 36 is for traction control option and does not affect drive-ability of the vehicle. it only appears when you jump the codes. There are two versions of the JDM p13 one has 3 plugs and the other has 4. The one with 4 plugs is the one that will throw code 36. If seeing the code every time you jump your codes drives you crazy you will need to get the 3 plug version. You can run either one with out problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnalJDMH22A &raquo;</TD></TR><TR><TD CLASS="quote"> This morning, My car would not start at all but it did turn sounded like it would start but it wouldn't. Any help would be great. Thanks</TD></TR></TABLE>
you may need to replace the infamous PGM-FI main relay which is under the drivers side dash. do a search, i know i posted the part number someplace on here
ckawjr
Mar 12, 2005 10:39 AM
carnifex
Oct 1, 2004 10:28 AM
HOTSHOT-H22A
Apr 21, 2004 09:35 AM
jdm94h22acivic
May 14, 2003 04:01 AM
