Tire Size Help For My 5th Gen 'Lude
Old 10-10-2003, 09:50 PM
boostedsol's Avatar
Default Tire Size Help For My 5th Gen 'Lude
I just got my new 16X7, +45mm rota slipstreams in today and I need to put some tires on 'em. I was thinking of getting 215/45/16 Falken Azenis tires to put on them. I have a 97 lude and I am dropped about 2 inches on koni yellow shocks and neuspeed sport springs. Is this the right tire size for the rims considering my 2 inch drop? What size tires would you all recommend? Thanks in advance. Btw, I did a search on this but I wasn't able to find any helpful info. regarding a 5th gen 'lude with this issue. Opinions regarding the Falken Azenis tires seem to be mixed on this board. My problem is that if the 215/45/16 tire is the right one for me there aren't a whole lot of other name brand tires in that size. The only decent tire I've found in that size is the Azenis. Help me out if you can fellas. Thanks in advance.
Old 10-11-2003, 12:40 PM
boostedsol's Avatar
Default Re: Tire Size Help For My 5th Gen 'Lude (boostedsol)
Up.
Old 10-11-2003, 02:28 PM
redmethods's Avatar
the size that came with the car
Old 10-11-2003, 02:32 PM
satan_srv's Avatar
stock tire size i 205/50/16, so yeah 215/45/16 is the correct sizing (slightly under stock). 215/50/16 also works but it's slightly larger than stock
Use this to play around with sizes to see the affect on speedometer and size. http://www.miata.net/garage/tirecalc.html
Old 10-11-2003, 04:50 PM
New User
Steppin Razor's Avatar
Default Re: Tire Size Help For My 5th Gen 'Lude (satan_srv)
I would go with 215/45 or 225/45. 225/50 is a little off, but still not bad. Azenis are great tires, but won't last terribly long.
Old 10-11-2003, 05:52 PM
boostedsol's Avatar
Default Re: Tire Size Help For My 5th Gen 'Lude (Steppin Razor)
Thanks for the help guys. I've made up my mind
Old 10-15-2003, 12:53 PM
luderacer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">stock tire size i 205/50/16, so yeah 215/45/16 is the correct sizing (slightly under stock). 215/50/16 also works but it's slightly larger than stock
Use this to play around with sizes to see the affect on speedometer and size. http://www.miata.net/garage/tirecalc.html</TD></TR></TABLE>
Will 215/50/16 rub? I'm thinking of getting this tire size.
Old 10-15-2003, 01:44 PM
bad-monkey's Avatar
Default Re: Tire Size Help For My 5th Gen 'Lude (luderacer22)
probably not but your car might feel a tad bit sluggish.
6SPD_EK
07-05-2008 06:58 AM
gooberwolf
12-05-2005 04:35 PM
IntegraBoy04
09-26-2003 02:22 PM
EKtypeRhaTcH
15
09-22-2003 04:02 PM
rlumd
07-01-2002 02:22 PM
Quick Reply: Tire Size Help For My 5th Gen 'Lude
