Camber Kit Question???
Old Oct 10, 2003 | 04:47 PM
importimage's Avatar
Default Camber Kit Question SRV???
I have a 93 VTEC. I am lowering the car about 2 inches. I have already purchased a front camber kit. I am wondering if the car requires a rear camber kit? If so, is it the same as the front camber kit?
Old Oct 12, 2003 | 04:34 PM
Default Re: Camber Kit Question SRV??? (importimage)
Does anyone put a camber kit in the rear on a 92-96 prelude?
Old Oct 14, 2003 | 02:52 AM
So, what do people do to get the rear camber corrected on a 93 prelude?
Old Oct 14, 2003 | 04:13 AM
killa_lude's Avatar
its not hard at all...you need to take the 2 screws that hold the upper control arm off...(engine bay located by strut nuts) once done, rotate the control arm so you have access to the 2 pivoting studs, then swap the camber kit w/ the stock non adjusting studs...
Old Oct 14, 2003 | 04:18 AM
satan_srv's Avatar
I quick SEARCH on 'Camber' has returned these threads
https://honda-tech.com/zerothread?id=437272
https://honda-tech.com/zerothread?id=425392
which led me to here
http://www.ingallseng.com/cars/honda.html and here
http://www.specprod.com/PROD_DIR/PROD_PASSCAR.html
I hate to say it again, but the archives have a wealth of information.
Old Oct 14, 2003 | 07:33 AM
del_parker's Avatar
i wouldn't worry about your rear camber. my rear tires barely wear at all with -2.5 degrees of camber in the back. just make sure your toe out is correct for the rear.
Old Oct 14, 2003 | 08:33 AM
92LudeSI's Avatar
It depends on your tires if your worried about camber wear. Some tires are fine with terrible camber and some will be eaten up within a few hundred miles. So its up to you basicaly. if you have a harder tire you could problably get by without a rear camber kit but if your like me and will eat through your tires get a kit. And yes for any uppercontrol arm type kits they are the same.
Old Oct 14, 2003 | 09:36 AM
Default Re: (92LudeSI)
So, does any brand names come tio mind for a rear camber kit???
Is the front camber kit not the same as the rear one...it sure looks similar???
Old Oct 14, 2003 | 02:06 PM
satan_srv's Avatar
Default Re: (importimage)
did you even check my links? It posts the same part numbers for front and rear.
Old Oct 15, 2003 | 01:43 AM
Default Re: (satan_srv)
I did now..thank you very much!!!
vlc92189
Suspension & Brakes
Dec 3, 2010 12:28 PM
LOC714
Sep 17, 2007 04:47 PM
fafsa
Apr 6, 2005 03:40 PM
lsvtec_DA
Feb 25, 2004 09:59 PM
