CKP Sensor....
Old Oct 14, 2003 | 10:10 AM
Slatelude's Avatar
Default CKP Sensor....
Okay '93 H23A stock ignition/distribution. Throwing CEL 4, where is the CKP Sensor and how do I fix this. Thought it was in the distributor....replaced guts....still throwing code after reseting the ECU. Help please!!!
Old Oct 14, 2003 | 02:09 PM
satan_srv's Avatar
Default Re: CKP Sensor.... (Slatelude)
it's in the distributor. Did you check your cam timing? Possiblyyour timing blt has slipped? Or it's a wiring issue
Old Oct 14, 2003 | 05:51 PM
Slatelude's Avatar
Default Re: CKP Sensor.... (satan_srv)
Satan,
Thanks, cam gears seem to be lining up fine, and the belt is only 15k old (i know it can happen whenever but its tight and dry as new) Read somewhere that there was some kind of Crankshaft sensor next to the oil pump on the "front" of the block...any ideas?
kevin
Efabe
Aug 9, 2017 02:59 PM
Efabe
May 11, 2017 06:23 AM
90RENOsedan
Dec 21, 2009 10:14 PM
snatch
Dec 13, 2004 04:28 PM
wickedxboi
Oct 28, 2003 08:12 PM
