Lowering Spring Install Question???
Old Oct 10, 2003 | 04:45 PM
importimage's Avatar
Default Lowering Spring Install Question???
I have just put a set of Suspenstion Techniques SpeedTech's in my 93 SRV. I cut the front bump stops in half. It looks as though the car is higher in the front than in the rear. Do I need to completly eliminate the front bump stops??
Old Oct 10, 2003 | 07:04 PM
rluder21's Avatar
Default Re: Lowering Spring Install Question??? (importimage)
The bump stops do not have anything to do with how low your car is. The bump stops prevent your shocks from bottoming out. Almost every car looks lower in the back than in the front with lowering springs. The reason is because the wheel well is cut differently in the rear which gives an appearence of the car being lower in the back when it is actually even throughout.
Old Oct 10, 2003 | 10:09 PM
92LudeSI's Avatar
If its a drastic difference you might have put the back springs in the front and vice versa if its just gradual then like rluder21 said
Old Oct 12, 2003 | 04:33 PM
Default Re: (92LudeSI)
Thanks for the info guys. I am not much of a prelude guy...I only know civics. As for my comment about the bump stops. All that I was thinking is that because the aftermarket spring is shorter than the OEM one, I figured that the spring was almost all the way compressed leaving no room for travel up and down as the bump stop is in the way. I understand what bump stops do, I just thought perhaps it is common that when doing a lower job on a 92-96 prelude that you eliminate them. As for the comment about putting the rear springs in the front, that has got to be the gayest thing I have ever heard. The wpring rates are completly different and the rears are not designed for the front. Bad advice, but thanks anyways.
itrdave
Feb 9, 2022 10:16 AM
fokai
Suspension & Brakes
Feb 13, 2006 02:04 PM
hondaracing1
Mar 28, 2005 09:32 AM
Asahi
Jun 10, 2004 11:26 AM
