VAFc VTM
Old Oct 12, 2003 | 12:38 PM
preludesh012001's Avatar
Default VAFc VTM
Does anyone know where you wire this up and is it just tapped to a stock wire or do you have to cut a wire? Its for a 5th gen.
Old Oct 12, 2003 | 01:02 PM
sharkcohen's Avatar
Default Re: VAFc VTM (preludesh012001)
It must be wired to C15 blue/black (vtec pressure switch). The stock wire needs to be cut, and the vafc wire spliced to the ecu side of C15.
Old Oct 12, 2003 | 01:36 PM
Shakes's Avatar
space cadet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludesh012001 &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know where you wire this up and is it just tapped to a stock wire or do you have to cut a wire? Its for a 5th gen.</TD></TR></TABLE>
I make the prediction that you will screw up your installation if you are doing it like you said.
Doug - who is a NASA certified soldering tech.
Old Oct 12, 2003 | 02:33 PM
So what do i do with the other side of this wire. What do i do to the engine side of the c15.
Old Oct 12, 2003 | 02:56 PM
sharkcohen's Avatar
Default Re: (preludesh012001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludesh012001 &raquo;</TD></TR><TR><TD CLASS="quote">So what do i do with the other side of this wire. What do i do to the engine side of the c15.</TD></TR></TABLE>
Nothing.
Old Oct 12, 2003 | 06:29 PM
So i just leave that C15 engine side wire on the ground. Its no longer needed?
Old Oct 12, 2003 | 06:50 PM
sharkcohen's Avatar
Yup.
projektvtec
Oct 3, 2005 09:04 AM
hondaZvic
Aug 6, 2004 11:40 AM
aces1980
Aug 1, 2004 10:05 AM
freeplay
Audio / Security / Video
24
Mar 13, 2004 09:06 AM
