1st gear vtec problem
Old Oct 8, 2003 | 01:01 PM
VTECLuDe96's Avatar
Default 1st gear vtec problem
sometimes when i drive my car hard... vtec doesnt seem to engage in 1st gear... then i shift to 2nd and 3rd and it works fine... same with everyother gear except for first. it engages in first one time but then it wont another time. any suggestions??? also i am 500 miles over due on my next oil change. could that be an issue... help please
Old Oct 8, 2003 | 01:13 PM
PhatboyNYC's Avatar
Default Re: 1st gear vtec problem (VTECLuDe96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECLuDe96 &raquo;</TD></TR><TR><TD CLASS="quote">sometimes when i drive my car hard... vtec doesnt seem to engage in 1st gear... then i shift to 2nd and 3rd and it works fine... same with everyother gear except for first. it engages in first one time but then it wont another time. any suggestions??? also i am 500 miles over due on my next oil change. could that be an issue... help please</TD></TR></TABLE>
Someone correct me if I'm wrong, but isn't VTEC engagement contingent on not only RPMS but also vehicle speed? Otherwise, you could hit VTEC just by revving the engine from a standstill. I think the car has to be moving at least 30-35 mph before VTEC will engage which might explain why you don't hear it in 1st gear.
Old Oct 8, 2003 | 01:17 PM
VTECLuDe96's Avatar
i dont feel the pull of vtec if that makes sense... all the other gears i can feel a pull... but sometimes in 1st i dont feel or hear anything
Old Oct 8, 2003 | 01:34 PM
PhatboyNYC's Avatar
Default Re: (VTECLuDe96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECLuDe96 &raquo;</TD></TR><TR><TD CLASS="quote">i dont feel the pull of vtec if that makes sense... all the other gears i can feel a pull... but sometimes in 1st i dont feel or hear anything</TD></TR></TABLE>
Perhaps you don't quite understand the concept of VTEC. VTEC isn't a miracle powerbooster that shoots your car forward when it engages. It's just a design that Honda came up with to maximize the powerband of the engine most efficiently. In 1st gear, there really wouldn't be a need to hit VTEC unless you're almost at redline I suppose and you're way past 30-35 mph.
Old Oct 8, 2003 | 01:40 PM
VTECLuDe96's Avatar
i dont think you are understanding what i am saying... when you mash your car you can feel vtec kick in... well sometimes when i mash my car... i dont feel anything... anyone else know what i am trying to say... phatboy i appreciate you trying to help but i just dont think you are understanding what im trying to say
Old Oct 8, 2003 | 02:25 PM
piotrush's Avatar
Did you check your oil level? vtecs like to burn oil and sometimes if its too low it wont engage. As for why only in first gear, I'm not sure. But check your oil regardless.
Old Oct 8, 2003 | 04:43 PM
KB96VTEC's Avatar
weird, i have a 96 VTEC lude and when i punch it in 1st i hear vtec roar everytime...
Old Oct 8, 2003 | 05:36 PM
rjr162's Avatar
Default Re: (KB96VTEC)
it's true VTEC won't enguage until you're moving. Sit still and revv it... you'll bounce at around 6200 rpm's, which is the rev limit when VTEC won't enguage. But as to be going 35... nah. Mine will hit it in first every time. Definantly check your oil level. Maybe your oil is just at the mark that when you get going in first the level seems too low, but after that since the sudden accel isn't there it's ok.
Old Oct 8, 2003 | 08:09 PM
Matgallis's Avatar
Default Re: (rjr162)
make sure ur stepping the gas all the way down
bb_SI
11
Jun 26, 2008 06:13 PM
midnitesol
May 12, 2006 08:32 PM
an2ny888
Mar 1, 2004 01:04 PM
kseriesDC5
14
Feb 16, 2004 04:52 PM
ALL-MOTOR-BUBBLE
Mar 18, 2003 10:05 PM
