Compression Numbers
Old Oct 8, 2003 | 08:13 PM
solowerks's Avatar
Default Compression Numbers
Did a compression test not to long ago, they came out 230psi across the board on a 93 vtec with 60k...That is higher than the Honda manual said the upper most tolerance could be..I have came to the conclusion I have some carbon build up..My question is does an increase in carbon build up actually make your car faster? I know its not wonderful for you motor...but if it increases the compression inside the cylinder than shouldn't it?
Old Oct 8, 2003 | 08:18 PM
PrecisionH23a's Avatar
Default Re: Compression Numbers (solowerks)
What does your manual list for the tolerances? In theory, if you have less combustion chamber volume you would gain more horsepower. But I doubt this is the case when it comes to carbon build up. Keep in mind having large deposits can attribute to poor flow patterns and even lead to hot spots. It all really depends how much carbon build up we are talking here and where it is accumulating at specifically.
Old Oct 8, 2003 | 08:25 PM
Honda318dx's Avatar
Default Re: Compression Numbers (GudeH23a)
Yea, thats REALLY high for an H22, certainly a 1993 one
Old Oct 8, 2003 | 08:29 PM
CHK4TIX's Avatar
whats a good why to remove carbon, if that is what causes the higher compression?
Old Oct 8, 2003 | 08:47 PM
4bidden's Avatar
Default Re: Compression Numbers (CHK4TIX)
My buddys 93 H22A1 came out with just about the same numbers. I think its normal....nothin to worry about until the numbers are inconsistent.
Old Oct 8, 2003 | 08:49 PM
Prelude Styl's Avatar
actually it IS the case when it comes to carbon build up. It actually does make the car faster. It's been dyno proven. Now, it's not good in all cases, if it builds up on the valve seats it causes them to not seal/seat correctly. But since your compression is evenly distributed, and nice and high, you have nothing but to be happy with your faster motor
Old Oct 8, 2003 | 09:01 PM
Kidd_Stylez's Avatar
a buddy of mine had a turbo Toyota MR2 which posted really high compression numbers, somewhere around the 210-215 range and thats on a car that is supposed to have a 8.5 - 1 C/R. They estimated that his car was around the 10 -1 C/R because of the build up and the owner just decided to replace the pistons.
Old Oct 8, 2003 | 09:03 PM
4bidden's Avatar
Default Re: Compression Numbers (Kidd_Stylez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kidd_Stylez &raquo;</TD></TR><TR><TD CLASS="quote">
a buddy of mine had a turbo Toyota MR2 which posted really high compression numbers, somewhere around the 210-215 range and thats on a car that is supposed to have a 8.5 - 1 C/R. They estimated that his car was around the 10 -1 C/R because of the build up and the owner just decided to replace the pistons.</TD></TR></TABLE>
I think thats a little extreme.....doubt its even possible to have that much buildup.
Old Oct 8, 2003 | 09:20 PM
KW2000's Avatar
Default Re: Compression Numbers (4bidden)
my h23a1 with 180000 miles ran 169 175 180 155 its a champ!
Old Oct 8, 2003 | 11:29 PM
aeolus's Avatar
Default Re: Compression Numbers (KW93LUDE)
both of my previous jdm h22a's had compression numbers around 235,240 or so...but that was a jdm motor....
Old Oct 9, 2003 | 01:18 AM
Default Re: Compression Numbers (aeolus)
My H23 puts out 195 across the board. 114k
Old Oct 9, 2003 | 07:14 AM
Behan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHK4TIX &raquo;</TD></TR><TR><TD CLASS="quote">whats a good why to remove carbon, if that is what causes the higher compression?</TD></TR></TABLE>
some octane boosters contain "carbon removing" agents. Or if you can find it, C-foam (or sea-foam, not sure on spelling) for fuel injected vehicles.
Old Oct 9, 2003 | 07:49 AM
solowerks's Avatar
The manual says
Nominal 185 psi
Minimum 135 psi
Maximum Variation 28 psi
The test was done at 250 rpm at WOT
Old Oct 9, 2003 | 11:00 AM
if you're still thinking it's bad.. don't. Don't worry about it. Just make sure you're putting in high octane fuel, and that your plugs are changed regularly, and you won't get an overcarbonized chamber. The part that REALLY matters, is the vairance between the cylinders. You don't want more than +- 5 per cylinder generally.
Old Oct 9, 2003 | 11:19 AM
symba's Avatar
Default Re: Compression Numbers (Prelude Styl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude Styl &raquo;</TD></TR><TR><TD CLASS="quote">My H23 puts out 195 across the board. 114k</TD></TR></TABLE>
Hey, I'm 195 across the board with 107,000 miles on my h23a
Old Oct 9, 2003 | 12:35 PM
solowerks's Avatar
Default Re: (Prelude Styl)
Nah I'm not too worried..Im rebuilding this winter.. My plugs are changed more than routinely, and I always run 94 octane fuel. The whole reason i did the test was to run some nawwwzzz, but the damn NMU is screwed up right now..waiting for a call about that as I type.
Old Oct 9, 2003 | 01:52 PM
SKDRCR's Avatar
Default Re: Compression Numbers (93preludevtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93preludevtec &raquo;</TD></TR><TR><TD CLASS="quote">
some octane boosters contain "carbon removing" agents. Or if you can find it, C-foam (or sea-foam, not sure on spelling) for fuel injected vehicles.</TD></TR></TABLE>
Your right it's sea foam and carquest has it
but i'm not sure if your supposed to put it in if your about
to rebuild your engine, kind of like engine restorer
Old Oct 9, 2003 | 02:34 PM
Default Re: Compression Numbers (symba)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by symba &raquo;</TD></TR><TR><TD CLASS="quote">
Hey, I'm 195 across the board with 107,000 miles on my h23a</TD></TR></TABLE>
Seems like that's the right number for us H23 guys.
Old Oct 9, 2003 | 04:15 PM
SKDRCR's Avatar
201k and 145 across, no nos
were talkin boss hoss lol j/k
Old Oct 9, 2003 | 05:34 PM
Default Re: Compression Numbers (SKDRCR)
You're serious right? 145 across. If so, I'd try another compressiont tester. I'd be willing to bet that those numbers jump up 40-50 psi each!~ The variance is the important part, and you don't have any apparently. Try another tester. I used a tester once that tested 50 psi low and got your numbers.
hondaeg5
20
Feb 14, 2004 04:50 PM
insomniac791
Jul 3, 2003 05:24 AM
1 2 NV
Jun 21, 2003 09:42 PM
mikeyvt
Dec 5, 2002 05:26 AM
