Problem with Heater in 92
Old Nov 29, 2003 | 08:57 AM
Knightmare69's Avatar
Default Problem with Heater in 92
My friend's prelude developed this problem somehow, the slider for the hot/cold section won't go towards the cold side. Yet there is no heat blowing out. Can this be a case of a blown heater motor? How can I be sure before we start looking for replacement parts?
Old Nov 29, 2003 | 12:06 PM
ludeR917's Avatar
Default Re: Problem with Heater in 92 (Knightmare69)
i had the same problem, you should check the cable on the back of the climate control?
Old Nov 29, 2003 | 01:11 PM
Default Re: Problem with Heater in 92 (ludeR917)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludeR917 &raquo;</TD></TR><TR><TD CLASS="quote">i had the same problem, you should check the cable on the back of the climate control? </TD></TR></TABLE>
I'm going to take out the unit sometime this week but I forgot if I have to take apart anything else to get that unit out. I'm gonna take it out and dissemble it to see what the exact problem is. Thanks for the input.
Old Nov 29, 2003 | 01:16 PM
yOnKiNaToR's Avatar
i have the same problem...you have to get under the hood and flip the switch on the bottom of the firewall manually until you get a new cable..that's what i'm doing now anyway
Old Dec 5, 2003 | 03:51 PM
I took a look at the car today, and I couldn't find the heater motor. I dunno if the fact that he has a H22 swaped in his 92 has anything to do with it. I adjusted any loose cables that we saw and the heater still does not work. I couldn't find the switch in the engine bay in the firewall. Can anyone please shed more info? Thanks in advance.
Old Dec 7, 2003 | 08:52 AM
Burrito
Old Dec 7, 2003 | 11:09 AM
jdm22vtec's Avatar
Default Re: Problem with Heater in 92 (yOnKiNaToR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yOnKiNaToR &raquo;</TD></TR><TR><TD CLASS="quote">you have to get under the hood and flip the switch on the bottom of the firewall manually until you get a new cable </TD></TR></TABLE>
that would be the more difficult way imo. the cable goes from the climate control to some sliding thing under the dash. its on the passenger side right next to the console. Pushing it towards the front of the car should give u hot air. Towards the back would be cold.
This seems to be a problem with 4th gen climate controls. I took out the cable and never put it back in cuz it was a pain in the rear. I can reach the slider thing on the passenger side from the drivers seat so u shouldnt have a prob getting to it.
this is what it looks like
Modified by jdm22vtec at 3:39 PM 12/7/2003
Old Dec 7, 2003 | 09:42 PM
Default Re: Problem with Heater in 92 (jdm22vtec)
Sweet, Thanks JDM22Vtec, I'll give that a look the next time I have time to work on his car. Is this the reason the switch won't slide to the cold side?
Old Dec 8, 2003 | 07:12 AM
chau003's Avatar
it wont slide because the cable that connects the climate slider and the switch went bad like someone else said earlier. I had the same problem where i would try to push the slider over to heat but it would shoot back to cold air. I replaced the cable and everything is fine now. Replaced it just in time for winter *whew*
Old Dec 8, 2003 | 07:13 AM
dankbudz11357's Avatar
Default Re: Problem with Heater in 92 (chau003)
i really wish i had a heater core and blower motor. it's a bitch driving with the windows down in the rain or when it's really cold.
Old Dec 8, 2003 | 03:00 PM
yohan's Avatar
quit being shy... go JDM Climate Control!!!
Old Dec 8, 2003 | 03:07 PM
jdm22vtec's Avatar
Default Re: (yohan)
pmp
25
Oct 5, 2011 09:13 PM
1HONDA4U2NV
Oct 13, 2009 12:25 PM
PhazedSI
Oct 28, 2005 09:18 PM
turboHX
Sep 28, 2004 08:18 AM
Agent Daimon
Jun 24, 2002 11:43 PM
