abs light
Old Dec 2, 2003 | 11:30 PM
noble4ws's Avatar
Default abs light
hey guys, i just drove my h22 4ws tonight, just finished the swap, and i have an abs light any idea where to start on that, or any big trouble areas to look for. i put new pads on it, and go the autozone passenger side axle, thanks
Old Dec 3, 2003 | 04:00 AM
wannabe's Avatar
Default Re: abs light (noble4ws)
I had some ABS problems in the past. The light on will throw a code and tell you where the problem is. Since you put on an axle, its probably a loose wire or bad connection for the speed sensor on that wheel.
Old Dec 3, 2003 | 04:58 AM
Crate's Avatar
if you just did a swap. Did you use the JDM Axels the swap came with? If so thats why. The JDM Axels are non-abs. I have the same light, i got axels in my shed just too lazy to put em on =]
Old Dec 3, 2003 | 05:09 AM
CHK4TIX's Avatar
Default Re: (Crate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crate &raquo;</TD></TR><TR><TD CLASS="quote">if you just did a swap. Did you use the JDM Axels the swap came with? If so thats why. The JDM Axels are non-abs. I have the same light, i got axels in my shed just too lazy to put em on =]</TD></TR></TABLE>
he said he got the auto zone axle.
So you need to check and see if the axle looks the same as the other axles. If i had a pic i would post what it should look like.
Old Dec 3, 2003 | 06:37 AM
h22mark's Avatar
Hey I swapped to a JDM f22b DOHC motor and my ABS light came on when I first had it. This would come on after a while of driving, but now it never comes on. I guess the h23a ECU corrected the problem.
Old Dec 3, 2003 | 06:45 AM
noble4ws's Avatar
thanks guys, i axle i bought was supposed to be abs, at least thats what i ordered
AccordParts
Mar 26, 2012 11:37 AM
oranginal
Sep 16, 2010 04:25 PM
ClarkS40
Mar 21, 2009 11:59 PM
TypeR0186
Nov 27, 2004 10:02 PM
Ls-Rturbo
Apr 5, 2004 02:01 PM
