Auto to manual conversion
Old Nov 24, 2003 | 10:45 AM
mac191's Avatar
Default Auto to manual conversion
How much do the manual conversions cost? and what parts are needed
92' Prelude Si
Old Nov 24, 2003 | 01:01 PM
Behan's Avatar
Default Re: Auto to manual conversion (mac191)
it depends on the car.
do a SEARCH
Old Nov 24, 2003 | 01:40 PM
mac191's Avatar
Default Re: Auto to manual conversion (93preludevtec)
well i have a 92' Honda Prelude Non-VTech Si
Old Nov 24, 2003 | 01:57 PM
jdm22vtec's Avatar
wow
Old Nov 24, 2003 | 03:43 PM
98vtec's Avatar
moderator emeritus
Default Re: Auto to manual conversion (jdm22vtec)
hahahaha rofl......haha....sorry almost started crying. hey he's gotta start learning sometime
Old Nov 25, 2003 | 06:09 AM
mac191's Avatar
Default Re: Auto to manual conversion (98vtec)
i can care less just someone answer my question
Old Nov 25, 2003 | 06:23 AM
jdm22vtec's Avatar
5 spd tranny
clutch/flywheel
hydraulic lines
pedal assembly
shift linkage
im sure there's others. but there's a start.
Try doing a search. I typed in auto to manual and got 475 results.
i'm sure you can find all of your answers there
Old Nov 25, 2003 | 06:30 AM
tec-9-7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mac191 &raquo;</TD></TR><TR><TD CLASS="quote">How much do the manual conversions cost? and what parts are needed
92' Prelude Si </TD></TR></TABLE>
Part 1 - Someone who wants to buy and automatic equipped Prelude.
Part 2 - Someone who has a manual equipped Prelude that they want to sell.
It's a pretty easy swap!
Paul
Old Nov 25, 2003 | 07:08 AM
spoolinlude's Avatar
I live under a rock
Default Re: Auto to manual conversion (tecX0r-9-7)
The conversion is somewhat of a pain since the preludes for one reason or another have a hydro splittter, which complicates the swap further, I have yet to figure out why honda did this, only reason I can come up with is a nicer pedal? Anyway, you'll need the linkage from in the car(shifter assm), the cables, all the plumbing, slave and master cylinders, the pedal assm from a manual lude, clutch, flyhweel, axles? i think?...... and a lot of patience, its not going to be easy
Old Nov 25, 2003 | 07:33 AM
skunk2lude01's Avatar
I know I cant do it,(but thats not saying much) But the shop I use will do it for 500 labor. Btw, I wish the mods would make it to where when vtec is spelled improperly it makes a ***** just like it automatically does if you type in certain web boards and adresses/
Old Nov 25, 2003 | 08:16 AM
JDM GIRL's Avatar
Ok, this is going to be long but here you go:
4th Gen Auto to Manual Transmission Conversion
<u>Parts List</u>
- Transmission
- Flywheel
- Clutch Assembly
- Slave Cylinder
- Clutch master cylinder
- All lines and dampener from master to slave cylinder
Including:
1. line from master cylinder to dampener
2. dampener, bracket and bolts to hold to fender
3. rubber line from dampener to adapter on transmission
4. adapter and bolt to hold to transmission
5. line from adapter to slave cylinder
6. bolt that holds rubber line to adapter (banjo-bolt)
- Starter for manual tranny
- Drivers side CV shaft and intermediate shaft
- Transmission mount and bracket
- Speedometer sensor (salvage yard may leave it on the tranny)
- Shifter cables, holding clips, clevis pins and cotter pins
- Shifter cable bracket for tranny (salvage yard may leave it on the tranny)
- Shifter assembly
- Shifter boot assembly and shift ****
- Clutch pedal assembly
- Both switches for clutch and their plug-in connectors
- Brake and gas pedal assembly
- 30 Amp Relay
- Manual ECU
<u>Bolts Needed</u>
- Transmission bolt that goes through starter and bolt below it (two longest bolts)
- Flywheel bolts
- Pressure plate bolts
- Slave cylinder bolts
- Intermediate shaft hanger bolts
- Transmission shifter bracket bolts
Note: The list of parts typed above were taken from a write-up, so if you want the step-by-step directions on how to perform this conversion, please pm me so that I can send you the file.
Oh, I almost forgot to mention that this will cost you a pretty penny. That's why I decided not to do it and to just seek out for a decent manual, in which I will continue to do for some time.
Old Nov 25, 2003 | 08:18 AM
del_parker's Avatar
Default Re: Auto to manual conversion (JDM GIRL)
do you really have to change ecu's?
Old Nov 25, 2003 | 09:14 AM
jdm22vtec's Avatar
Default Re: Auto to manual conversion (del_parker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del_parker &raquo;</TD></TR><TR><TD CLASS="quote">do you really have to change ecu's?</TD></TR></TABLE>
dont know but i would change the gauge cluster so u dont have to look at
P
R
N
D
Old Nov 25, 2003 | 09:49 AM
You dont have to look at that now, the only difference is ss has a little electronically controlled box that states wether you in 1,2,3,4 gear....
Old Nov 25, 2003 | 03:35 PM
jdm22vtec's Avatar
Default Re: Auto to manual conversion (skunk2lude01)
oh...well i was talkin about the 4th gens. One of my friends did a manual swap and left the auto cluster in. Park was always lit up. That would **** me off...
Old Nov 25, 2003 | 06:02 PM
luder94-ChrisA's Avatar
I still have my old auto cluster & nothing is lit up
Old Nov 25, 2003 | 06:36 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">do you really have to change ecu's?</TD></TR></TABLE>
Yeah, unless you want it to run like crap and always have a CEL.
Old Nov 25, 2003 | 11:27 PM
del_parker's Avatar
Default Re: Auto to manual conversion (Jim Truett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah, unless you want it to run like crap and always have a CEL. </TD></TR></TABLE>
how would it do that?
are the fuel curves different or something?
Old Nov 26, 2003 | 12:02 AM
KW2000's Avatar
who needs a new gauge cluster..just get a MT white face gauges they lay right over the AT guage cluster and there ya go...no more PRND4D321
Old Nov 26, 2003 | 03:01 AM
CanadaRed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tecX0r-9-7 &raquo;</TD></TR><TR><TD CLASS="quote">
Paul</TD></TR></TABLE>
This is by far the best and easiest way to do it. Not worth the cost of doing the conversion IMO.
Old Nov 26, 2003 | 04:30 PM
Jim Truett's Avatar
are the fuel curves different or something?</TD></TR></TABLE>
No, the fuel and timing are pretty much the same, but the ECU will be looking for a transmission that is no longer there.
Old Nov 26, 2003 | 08:01 PM
Jim Truett's Avatar
Default Re: Auto to manual conversion (CanadaRed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CanadaRed &raquo;</TD></TR><TR><TD CLASS="quote">
This is by far the best and easiest way to do it. Not worth the cost of doing the conversion IMO.</TD></TR></TABLE>
I hate to say it, but if you own that '97 SS that's in your sig you may find yourself in need of a swap or repairs if you plan on keeping the car. The best price I have found for a SS tranny is $1100.00 rebuilt, and that does not include the torque convertor. The cost of the swap is around $1500.00 to $1600.00 without labor factored in. A good read for 5th gen SS 'lude owners: http://hpoa.org/forumdisplay.php?f=11
Old Nov 26, 2003 | 08:21 PM
del_parker's Avatar
No, the fuel and timing are pretty much the same, but the ECU will be looking for a transmission that is no longer there.</TD></TR></TABLE>
But doesn't the AT ECU take care of that? Why would the other ECU matter?
Old Nov 27, 2003 | 07:36 AM
mac191's Avatar
How much will all the parts cost.... i need to get a estimate on how much this will cost because it will be getting done in 2 weeks
Old Nov 29, 2003 | 07:50 AM
Jim Truett's Avatar
But doesn't the AT ECU take care of that? Why would the other ECU matter?</TD></TR></TABLE>
The Prelude has a TCM (transmission control module) that has a data communications link with the ECU. Once the TCM is disabled or disconnected from the transmission or the ECU the CEL will be illuminated, and the ECU will run in limp mode. The only way around this is to get a manual ECU or convert the auto ECU to manual internally.
