high compression valves
Old Nov 24, 2003 | 05:48 PM
black_bb1's Avatar
Default high compression valves
When my timing belt went I guess some valves got bent in the process. about how much would high comp valves raise my overall compression. also seeing as im damn near broke would I be hurting anything if I drove around on a few bent vlaves? Im looking for oppinions on wether high comp valves are a worthey upgrade or not?
Old Nov 24, 2003 | 06:29 PM
TurboSam's Avatar
Default Re: high compression valves (black_bb1)
valves dont rasie compression, pistons do
Old Nov 24, 2003 | 06:41 PM
laughinxxx's Avatar
New User
Default Re: high compression valves (Turbo Sam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo Sam &raquo;</TD></TR><TR><TD CLASS="quote">valves dont rasie compression, pistons do</TD></TR></TABLE>
**shakes head**
Old Nov 24, 2003 | 06:59 PM
kentucky accord's Avatar
LOLOLOOL
Old Nov 24, 2003 | 07:02 PM
Cottonwoodz's Avatar
No, silly.........Valves dont raise compression, milled heads do.
Old Nov 24, 2003 | 07:03 PM
infinatenexus's Avatar
You don't get out much do you?
Old Nov 24, 2003 | 07:06 PM
TurboSam's Avatar
Default Re: high compression valves (infinatenexus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infinatenexus &raquo;</TD></TR><TR><TD CLASS="quote">
You don't get out much do you?</TD></TR></TABLE>
then someone please tell me how valves rasie compression?
laughinxxx's Avatar
New User
btw, the increase in compression will only be about .3.
TurboSam's Avatar
Default Re: high compression valves (Cottonwoodz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cottonwoodz &raquo;</TD></TR><TR><TD CLASS="quote">
No, silly.........Valves dont raise compression, milled heads do. </TD></TR></TABLE>i was just giving the simplest answer
Old Nov 24, 2003 | 07:11 PM
then someone please tell me how valves rasie compression?</TD></TR></TABLE>
The valve face is flat, not concaved. That occupies more space in the combustion chamber, and incerases compression.
Old Nov 24, 2003 | 07:14 PM
TurboSam's Avatar
The valve face is flat, not concaved. That occupies more space in the combustion chamber, and incerases compression.</TD></TR></TABLE>
yea, but the increase is so little, i hardly call that "high compression", you wouldn't raise the compression enough to get a noticeable power increase except on a dyno, and even then, it wouldnt hardly be visible just to look at the graph
Here is some Junk2 I mean Skunk2 I high comp valves, eh..
Old Nov 24, 2003 | 07:18 PM
yea, but the increase is so little, i hardly call that "high compression", you wouldn't raise the compression enough to get a noticeable power increase except on a dyno, and even then, it wouldnt hardly be visible just to look at the graph</TD></TR></TABLE>
.3-.5 isnt exactly a small increase
Anywho, Anyone know how good Skunk2's stage 1 cams are?
94typeR
Apr 10, 2007 11:42 AM
radeon
10
Mar 29, 2007 08:50 AM
Dammit_Dan_954
Dec 7, 2003 08:44 AM
NeVeR bLoWn
Oct 20, 2003 02:29 PM
