CLUTCH??
Old Nov 30, 2003 | 04:37 PM
CerealKiller1117's Avatar
Default CLUTCH??
My clutch peddle has no pressure behind it, the clutch will not engage and it just revs, i can turn the car on, move the shifter etc, what is wrong with my car? did my clutch go or is it a pressure plate? i dont know anything about clutches other than how how to drive it, and i know clutches dont last forever and this is my first stick car so i probably didnt drive it the best but it shouldnt have done this, 90 000 mi, 92 Si
Old Nov 30, 2003 | 05:01 PM
Yield's Avatar
probably have a leak in your master or slave cylinder. Look by the pedals on the firewall. If you see fluid coming down the firewall where the clutch goes through, its the master, otherwise probably the slave. Often fail when it gets cold.
Old Nov 30, 2003 | 11:18 PM
Gerhard_001's Avatar
Default Re: CLUTCH?? (CerealKiller1117)
Your slave cylinder is shot, Clutch master cylinder may be shot. You are getting air into you hydraulic line from the clutch master cylinder to the slave somewhere. Examine both, if either or is gone bad you will see one of the two leaking.
Old Dec 1, 2003 | 12:42 AM
dankbudz11357's Avatar
Default Re: CLUTCH?? (Gerhard_001)
mine has a little fluid leaking, very slow though. better get that fixed, this kind of reminded me of it. you might as well replace both of them anyways, just in case. better safe than sorry. i think i'm gonna do that this weekend.
96civic turbo
Transmission & Drivetrain
Jun 5, 2010 11:09 AM
hYbRiD EeEkAy
Aug 7, 2008 11:27 AM
RDAYA0
Dec 14, 2006 05:31 PM
myhatchrips
Dec 5, 2003 07:21 AM
