sunroof inserts?
Old Nov 27, 2003 | 04:08 PM
NoLipRacen's Avatar
Default sunroof inserts?
ive seen these available for the crx/efs but are they any manfactured one that you can buy? i can only imagine how much weight it would take off. and if not then how hard would it be to make one? just a shot in the dark here but would just need some CF cut to size sealant and a way of securing it down? or would it be more dollar per pound affective to just weld in a sheet of aluminum? thanks!
Old Nov 27, 2003 | 04:22 PM
SUB-0 H23's Avatar
Default Re: sunroof inserts? (LudeTuner)
if you own a 4th gen satan_srv should hav a cf sunroof ready in a month.
Old Nov 27, 2003 | 07:40 PM
satan_srv's Avatar
Default Re: sunroof inserts? (SUB-0 H23)
well if you just wan an insert I think someone was working on one of those...mine would be an OEM replacement but it would be applicable as a plug as well I would think
Old Nov 27, 2003 | 07:51 PM
kkw103's Avatar
Would the sunroof still work if the CF insert was used?
Old Nov 27, 2003 | 07:55 PM
4bidden's Avatar
Default Re: sunroof inserts? (shaiboyr)
There is a post on PO that says raceplates.com will make one for the 4gen, cost is outrageous for a plug though.
Old Nov 27, 2003 | 07:57 PM
satan_srv's Avatar
Default Re: sunroof inserts? (4bidden)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4bidden &raquo;</TD></TR><TR><TD CLASS="quote">There is a post on PO that says raceplates.com will make one for the 4gen, cost is outrageous for a plug though. </TD></TR></TABLE>
That's what I was thinking of. How much were they asking?
Old Nov 28, 2003 | 08:05 AM
bdb's Avatar
bdb
Default Re: sunroof inserts? (satan_srv)
~$350 USD for the kit.
Old Nov 28, 2003 | 09:11 AM
NoLipRacen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shaiboyr &raquo;</TD></TR><TR><TD CLASS="quote">Would the sunroof still work if the CF insert was used?</TD></TR></TABLE>
no the idea is to remove the entire sunroof then cover it and seal with a sheet of CF, dropping +50lbs from the highest point on the car
Old Nov 28, 2003 | 10:04 AM
dankbudz11357's Avatar
would definitely be a good idea to get one. 350 seems steep, i'd settle for a fiberglas one.
.Ryan
Jul 13, 2008 02:21 PM
Chris F
May 19, 2008 09:05 AM
SHPrelude00
Jan 10, 2007 12:14 PM
CRXracer88
Dec 30, 2003 03:18 PM
Quade
Sep 21, 2003 05:23 PM
