Let's talk Flywheels!
Old Nov 28, 2003 | 09:50 AM
NoLipRacen's Avatar
Default Let's talk Flywheels!
ok i just bought an m2b4 tranny but i still have a few more things on my list... first off has anyone (and i know this has been talked about before) run a hyper clutch? like the one seen on JDMsh*t!? how do you like it? both for daily and spirited driving? would this clutch be suitable on an N/A SCCA racer? or would i need something stronger? i would like a sprung clutch because it gives me the ability to drive a little "smoother" you know? next up are flywheels, i dont think i need anything extreme like an 8lbi think i would rather have a 11lb, keep in mind mostly a streetcar, but for those of you who know everything about h22s please give me the pros and cons so i can make a better decision. also on the subject of flywheels, what kind of material should i look into? any specific manufactures? thanks guys!
EDIT: the tranny i bought is dirtys hell what would the best method for cleaning it?
Modified by LudeTuner at 7:15 PM 11/28/2003
Old Nov 28, 2003 | 10:37 AM
D16OnTop's Avatar
bump for the coke can
Old Nov 28, 2003 | 10:45 AM
H22A EG6's Avatar
Default Re: (CodeDawg)
i just bought a aasco fly wheel have not used it yet it was damn spendy should have lookeed around moe i guess it is good b/c you can replace the contact area
Old Nov 28, 2003 | 11:10 AM
scrubachu's Avatar
Default Re: (H22A EG6)
i had a fidanza lightened flywheel, and that thing gave me tons of headaches. granted the car was fast as hell off the line, but after sprying a 75 shot, the bolts to it backed out and i had to pull the tranny 2 separate times. i even had the red loctite on it. my guess on why it backed out is because aluminum expands when it is heated as opposed to steel which compresses. other than that who, knows... my stock one is back in and no problems..
Old Nov 28, 2003 | 11:34 AM
NOTENOUGHBOOST's Avatar
Default Re: (scrubachu)
If your worried about dependablity, leave your factory flywheel on!!!!
Just my $0.02
Old Nov 28, 2003 | 11:53 AM
preluda92's Avatar
Default Re: (littlechoppab20)
I've got the Fidanza ultra-light (8.5lb) and I've had no problems with it. You get used to controling the revs in about 2.2 seconds and anyone racing SCCA is bound to have knowledge of heel-toe and rev matching so you'll never have to worry about "losing revs" between shifts. I always rev match and it probably took me a day to get used to how hard I had to push the gas to get the engine where I wanted it. Now that I'm used to it I'd never go back to a stock flywheel. You'll love it believe me.
Old Nov 28, 2003 | 12:00 PM
laughinxxx's Avatar
New User
Default Re: (preluda92)
R and D got some new chromoly flywheels in. They are one piece with low rotational mass and are 8-9 lbs.
Old Nov 28, 2003 | 12:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preluda92 &raquo;</TD></TR><TR><TD CLASS="quote">I've got the Fidanza ultra-light (8.5lb) and I've had no problems with it. You get used to controling the revs in about 2.2 seconds and anyone racing SCCA is bound to have knowledge of heel-toe and rev matching so you'll never have to worry about "losing revs" between shifts. I always rev match and it probably took me a day to get used to how hard I had to push the gas to get the engine where I wanted it. Now that I'm used to it I'd never go back to a stock flywheel. You'll love it believe me.</TD></TR></TABLE>
How long have you been using your Fidanza flywheel?
Old Nov 28, 2003 | 01:59 PM
p3s7's Avatar
I also run the fidanza flywheel (8.8lbs) and its great, I've had no problems whatsoever, I didn't even kill the car once after it was installed. The revs dropping faster is not that big of a deal, car revs much more freely. If you're wanting one and have the money I'd go with it if you auto-x. Oh yeah I've been using it with the act hd/ss in my 4th gen vtec for about 6 months/8k miles.
Old Nov 28, 2003 | 02:04 PM
Nick M's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littlechoppab20 &raquo;</TD></TR><TR><TD CLASS="quote">If your worried about dependablity, leave your factory flywheel on!!!!
Just my $0.02</TD></TR></TABLE>
care to explain?
Old Nov 28, 2003 | 02:51 PM
Default Re: (Nick M)
[QUOTE=Nick M]
care to explain?[/QUOUTE]
I've had problems with the flywheel warping... I've seen it happen to a few of the prelude owners in my area, that's why I am against alumium flywheels
Old Nov 28, 2003 | 03:22 PM
del_parker's Avatar
Default Re: Let's talk Flywheels! (LudeTuner)
the ring gear came loose from my Clutchmasters 8lb flywheel. you might want to just get a lightened stock flywheel.
for cleaning it, it's going to get dirty again, but you can use carb cleaner.
Old Nov 28, 2003 | 03:52 PM
alphajesse's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scrubachu &raquo;</TD></TR><TR><TD CLASS="quote"> my guess on why it backed out is because aluminum expands when it is heated as opposed to steel which compresses.</TD></TR></TABLE>
EVERYTHING expands when it gets hot, even steel. It just doesn't expand as much as aluminum.
Old Nov 28, 2003 | 04:26 PM
satan_srv's Avatar
Default Re: Let's talk Flywheels! (del_parker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del_parker &raquo;</TD></TR><TR><TD CLASS="quote">the ring gear came loose from my Clutchmasters 8lb flywheel. you might want to just get a lightened stock flywheel.
for cleaning it, it's going to get dirty again, but you can use carb cleaner. </TD></TR></TABLE>
I have the same clutchmasters. I haven't had any problems for 2 years FWIW
Old Nov 28, 2003 | 04:38 PM
SKDRCR's Avatar
Default Re: Let's talk Flywheels! (satan_srv)
lightened stock flywheel works fine for me
Old Nov 28, 2003 | 05:28 PM
Nick M's Avatar
Default Re: Let's talk Flywheels! (SKDRCR)
I ran a 9lb Aasco for more than a year on my h22a, never had a problem, the guy who owns it now hasnt had a problem either.
Old Nov 28, 2003 | 05:47 PM
JG Luder's Avatar
Default Re: Let's talk Flywheels! (Nick M)
I ran a Unorthodox Racing 9 lb (you can only get them in 10 lb from them now) back in the day. No probelms out of it till it got stolen.
I also used an ACT Xtreme PP and 6 puck disk. Horrible for street driving.
Held all the power and abuse I could throw at it though.
HotWheelz's Avatar
clutchmasters flywheel, ACT extreme clutch.. no problem..
Old Nov 28, 2003 | 08:11 PM
NoLipRacen's Avatar
Default Re: Let's talk Flywheels! (HotWheelz)
what about chromoly as a material are there any issues there? and once again has anyone tried this hyper clutch out?
Old Nov 28, 2003 | 10:56 PM
skrewdlude's Avatar
I have had my Fidanza for over 3 years now, and I can say that it is GREAT! I had a slight grinding (when starting)problem with it, but called them to ask talk to them about it, and guess what? They overnited me a brand new one. They were really nice to deal with too. They ended up getting Tom Fidanza on the phone, and he was incrediblely knowledgeable. He explained exactly what had happend, and apologized for the inconvinence. Had the new one for quite a bit now and NO problems. When I last pulled my motor, I checked all the bolts again and everything was still tightened to spec. You are suppose to loctite the main bolts on fyi. also clutchmaster = fidanaza just rebaged
Josh
Old Nov 30, 2003 | 01:51 PM
wannabe's Avatar
I've had a Jun chromoly flywheel 2 years, no problems. I've seen drag cars with prelude engines cause warping on aluminum flywheels. Thats why I paid more for chromoly. It won't warp like aluminum.
Old Nov 30, 2003 | 02:04 PM
Default Re: Let's talk Flywheels! (wannabe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wannabe &raquo;</TD></TR><TR><TD CLASS="quote">I've had a Jun chromoly flywheel 2 years, no problems. I've seen drag cars with prelude engines cause warping on aluminum flywheels. Thats why I paid more for chromoly. It won't warp like aluminum.</TD></TR></TABLE>
Now that it is time to change out my clutch again, I plan on try the Jun chormoly one.... Hopefully I don't have any problems out of it!
Old Nov 30, 2003 | 09:07 PM
4gen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HotWheelz &raquo;</TD></TR><TR><TD CLASS="quote">clutchmasters flywheel, ACT extreme clutch.. no problem..</TD></TR></TABLE>
same thing except for street performance clutch, never had a problem.
Old Nov 30, 2003 | 09:49 PM
Cementups's Avatar
Default Re: Let's talk Flywheels! (4gen)
Chromoly is your best otion when it coems to light weight flywheels. More resistant to warping. The only ones I've seen available is the JUN and now ACT has chromoly flywheels out for the Prelude as well.
Old Nov 30, 2003 | 10:47 PM
del_parker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">
I have the same clutchmasters. I haven't had any problems for 2 years FWIW</TD></TR></TABLE>
i figured out what was wrong with the flywheel, the ring gear had about a .0015" gap around a third of the wheel which allowed it to flex and vibrate on startups. since clutchmasters only uses 3 screws with washers to hold the ring gear in place it wore away at the washers over the past 15 months that i've had it. it literally sheared away a third of each washer that holds it in place.
