Difference Between Driver and Passenger Side Axles
Old Jul 26, 2011 | 09:46 AM
cmbr's Avatar
10 Year Member
Icon2 Difference Between Driver and Passenger Side Axles
Soon I'll replace the driver side axle assembly on my 1988 Honda Prelude 2.0 Si 2WS automatic (if I can ever get the nut off). When under the car last week I noticed that the constant velocity joint boots on the passenger side are now cracked.
The online vendors list separate products for the driver and passenger side axles. On the other hand, my Honda service manual doesn't make any distinction. Can I rebuild the driver side axle and use it on the passenger side? What, if any, are the differences?
Old Jul 26, 2011 | 02:17 PM
typemismatch's Avatar
Honda owns me
Default Re: Difference Between Driver and Passenger Side Axles
Length, one is longer than the other I believe
Old Jul 26, 2011 | 02:34 PM
cmbr's Avatar
10 Year Member
That might be it. The service manual only shows that both sides have a length of 19.5 inches from the outboard ring to the inboard joint. That doesn't include the splines and threaded end. The dimensions of the outermost parts are not given.
Old Jul 26, 2011 | 02:53 PM
Honda owns me
I could be wrong though, if you have them both out, measure them and check for differences, then share what you find.
Carasith
Nov 15, 2018 06:03 PM
Freefallin99
Honda CR-V & Element
Feb 27, 2017 02:35 PM
powerneedy
23
Oct 5, 2011 02:08 PM
soon2bdropped
May 9, 2007 06:56 PM
( o )( o )
Sep 7, 2005 11:57 AM
