AC compressor not engaging
Old Aug 9, 2011 | 01:56 PM
saikou's Avatar
Default AC compressor not engaging
Just re-installed all AC components into my 93 and had the system pressure/leak tested and results are negative - no leaks. I also had my circuit board from the climate control re-soldered and that fixed the non-responsive vents.
Now, that the AC system is filled with freon, we can't get the compressor to come on. All I recall seeing from the compressor is one plug for power. Isn't there supposed to be a ground wire? Would I be able to put direct power to this compressor to check if it's working as well? Thanks.
Old Aug 9, 2011 | 03:20 PM
minilogoguy18's Avatar
Default Re: AC compressor not engaging
Clutch does not engage when everything is on? Have you checked if there is power at the compressor?
Old Aug 9, 2011 | 05:22 PM
saikou's Avatar
Not yet. I haven't had a chance to check if any fuses were burnt but have found out I can directly put 12v of power to the compressor without damaging it. So, I will need to see if that'll engage the clutch and go from there. Also, it shouldn't matter that my condenser fan is a slim fan and not factory, right?
Old Aug 9, 2011 | 08:22 PM
saikou's Avatar
For all you dumb asses like me, please make sure the #11 fuse is in your kick panel fuse box - ice cold now!
thisguyaves
Honda Civic (2001 - 2005)
Jun 3, 2018 01:47 PM
TonyI
Apr 16, 2018 08:00 PM
bradybunch2101
Oct 22, 2012 04:38 AM
imjustagirl
Aug 19, 2007 08:54 PM
superfuji57
Jul 14, 2007 05:38 PM
