just bought my lude
Old 08-08-2011, 10:52 AM
jshaw23's Avatar
Default just bought my lude
I just bought my 1998text bonds prelude and noticed after driving for a little bit that the temp is running almost dead center. It didn't over heat but it is running warm in my opinion and was wonder if this is a early warning sign of something going wrong. Checkejmd to cooling system for bubbles already.
Old 08-08-2011, 11:10 AM
Hidenplanvew's Avatar
Default Re: just bought my lude
Middle? I think mine runs about 1/2 way you could always replace the Tstat but it would be best to get a true temp
Old 08-08-2011, 11:41 AM
Honda owns me
typemismatch's Avatar
Do your fans kick on and off properly?
I know my 92(4G) runs at the middle all the time, I know its an older car, but basically the same motor.
My actual temp reads ~200 degrees, on an AEM water temp guage, and the fans come on ~205-210. I'm boosted and running a Koyo half radiator, but my actual in car display looks like it always did with an F22 SOHC non-VTEC, and with the JDM H22 when it wasn't boosted, half way.
Old 08-08-2011, 12:37 PM
jshaw23's Avatar
Yeah fans kick on like they should I just wasn't sure if there was an issue. It has been a while since I had a prelude and couldn't remember it being that warm
Old 08-08-2011, 01:04 PM
Honda owns me
Mine is a 4G though, I only have 4 digital bars for my temp in the dash, not an analog gauge. I think the second bar that goes to the halfway mark turns on somewhere between 150-170 degrees an I think you have to be 220-230+ for it to go into the 3rd bar.
If you're concerned about it, hook up an aftermarket temp sensor and check, if you're not running crazy hot, don't worry about it.
If you want to worry about it anyway, go get a lower temp thermostat, they should only be $10-20, I know Rockauto sells them for like $5.
Old 08-08-2011, 04:00 PM
jshaw23's Avatar
Icon3 Re: just bought my lude
Thanks everyone for the help
Old 08-08-2011, 04:50 PM
DJ_SaNdOz's Avatar
The h series motors seem to run a little hot anyway IMHO, but 1/2 is normal.
brokenojoke
14
01-14-2008 07:37 PM
projectef
11
06-21-2007 04:49 PM
AnthonyG2003
11-27-2005 03:56 PM
zzzkenji
04-23-2003 06:06 PM
Steve Berman
04-17-2003 12:45 PM
Quick Reply: just bought my lude
