open diff to quaife lsd
Old Aug 27, 2011 | 08:10 AM
mach3lude's Avatar
Default open diff to quaife lsd
is that gear on the open differential suppose to come off and go on the quaife lsd? its going on a m2f4 with a mfactory final drive also.
Old Aug 27, 2011 | 07:58 PM
117's Avatar
117
Default Re: open diff to quaife lsd
Yes. You need to remove the speedo gear and press it onto the Quaife. Be careful, you cannot purchase the gear separately from Honda.
Old Aug 28, 2011 | 06:36 AM
InvaderTrax's Avatar
Swap the speedo gear (thing the arrow's pointing at) and replace the bearings on both ends. When we installed mine it fit perfect with the original shim from the factory diff
Old Aug 28, 2011 | 07:41 AM
117's Avatar
117
BTW, I used a bit of heat and a gear puller to remove the speedo gear.
+1 on replacing the bearings. Double check the preload. I've always had to use a different shim.
Old Aug 29, 2011 | 07:18 AM
mach3lude's Avatar
i got the gear off and put it on the lsd and installed new bearings. having trouble finding out what the clearance is suppose to be once i install it in the case to determine if i need to shim it or not.
sorry about all this, i had this info before but then i lost it and now i cant find it again.
jceltalentoso
Transmission & Drivetrain
May 13, 2014 09:05 PM
InfamousDC2FI
May 13, 2006 07:59 PM
Shmaa
May 24, 2005 12:52 AM
d_mina
Oct 13, 2003 10:06 PM
PupaScoopa
Apr 8, 2003 10:01 AM
