Finally found the problem with my old motor...
Old Jan 9, 2005 | 10:27 PM
Keith's Avatar
Default Finally found the problem with my old motor...
Hey guys,
And weeks of procasinating, I finally took the time to open up my old motor to find out the problem with it...
After taking apart the head, and not finding anything wrong with it, we proceeded to disassemble the block and found this for cylinder 2...
Rod cap... (note, marks on the center are probably caused by me, trying to pry the cap off the rod.
That explains the metal shavings in my oil pan...
Now on the track this happened on, there are a couple of sharp turns where I take it at high revs which could have been a cause of oil starvation which caused the spun bearing... OR maybe it just the motor's time since it has well over 150K miles on her... OR maybe a combination of the two...
My concern is moving forward, how can I prevent this from happening to my new motor? What are my options besides a baffled oil pan?
Keith
Old Jan 10, 2005 | 12:34 AM
ludegetsmwet's Avatar
Default Re: Finally found the problem with my old motor... (Keith)
that is one f!@W#$ up bearing sorry to here about that dude
Old Jan 10, 2005 | 01:49 AM
satan_srv's Avatar
Default Re: Finally found the problem with my old motor... (ludegetsmwet)
what oil were you using? Use a thicker weight at operating temperature...like 15w50 mobil high perf or what I was using German Formula Castrol 0w30...very close to 40 weight at operating
Old Jan 10, 2005 | 05:26 AM
Keith's Avatar
Default Re: Finally found the problem with my old motor... (satan_srv)
I was using Mobil 5W30, non synthetic... A thicker weight of oil eh? Hmmm...
Keith
Old Jan 10, 2005 | 05:42 AM
JadedGamerX's Avatar
satan, how does going to a thicker weight stop high G starvation?
Old Jan 10, 2005 | 07:20 AM
98TypeSH's Avatar
Default Re: Finally found the problem with my old motor... (JadedGamerX)
isnt there some companys around that will baffle your pan ? If you are going to autox the beast alot, id say invest in a baffled pan or getting yours baffled.
Old Jan 10, 2005 | 07:40 AM
LudeyKrus's Avatar
Dun dun dun.......another one bites the dust!
If you're sure that it was caused by oil starvation caused by heavy lateral g-forces, then you have two options that i am aware of: either get a baffled oil pan or go w/ an Accu-Sump setup.
Good luck man!
Old Jan 10, 2005 | 07:50 AM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JadedGamerX &raquo;</TD></TR><TR><TD CLASS="quote">satan, how does going to a thicker weight stop high G starvation?</TD></TR></TABLE>
his failure was a spun bearing, he asked about options other than a baffled oil pan to reduce this possibility.
I agree lateral-G interrupting oil lubrication was probably the cause, but there are many other causes to spun bearings, which I am trying to address, since he said other than baffled pans. Make sense?
Plus, I think a thicker weight oil would have caused the bearings to hold out at least a little longer
Old Jan 10, 2005 | 08:55 AM
machine4321's Avatar
is i tme or is there a chunk missing of the cranks in the first pic...could just be the angle
Old Jan 10, 2005 | 08:58 AM
getnasty's Avatar
Default Re: (machine4321)
looks like chunk missing to me
Old Jan 10, 2005 | 09:22 AM
Keith's Avatar
No, it was the bearings overlapping each other...
keith
Cheyenne Lanae
Dec 23, 2018 07:04 PM
diatibe24
Oct 10, 2016 01:01 PM
OrangeTeggy
24
Nov 2, 2012 06:59 AM
97grnrs
Dec 20, 2005 03:10 PM
BlackT5
Mar 2, 2005 07:04 PM
