suspension bolt difficulty
Old Jan 6, 2005 | 06:44 PM
yOnKiNaToR's Avatar
Default suspension bolt difficulty
i'm having a problem with getting a bolt off to get at a bushing and was hoping someone else has already done this.
on the rear of the prelude, there is a rear arm, i think maybe the arm behind the LCA...it has a self locking bolt on one side and a nut with a weird shaped washer on the other side.(i think this is to adjust toe?) anyway, how do i totally remove the bolt? i can get the nut off just not the bolt.
Old Jan 6, 2005 | 06:48 PM
yOnKiNaToR's Avatar
Default Re: suspension bolt difficulty (yOnKiNaToR)
btw, the bolt is almost stripped b/c i tried loosening it but it was too tight.
Old Jan 6, 2005 | 11:00 PM
yOnKiNaToR's Avatar
bump
Old Jan 8, 2005 | 06:45 PM
yOnKiNaToR's Avatar
anybody know?
Old Jan 8, 2005 | 07:04 PM
funkmasterchipz's Avatar
i had a similar problem becuase my LCA was bent and the bolt in the wheel hub was also.....what me and my dad tried was getting the impact rachet on it that didnt work....then we tried the air hammer........didnt work for us.....we eventually drilled the material of hte bolt away till it would pop out.....good luck
Old Jan 8, 2005 | 07:36 PM
yOnKiNaToR's Avatar
Default Re: suspension bolt difficulty (funkmasterchipz)
so basically once the nut is off that bolt should slide right out or does it have to be screwed out? if it just slides, i'm thinking it won't come out b/c the pressure of the arm is pressing the bolt against metal so if i put the jack under that arm and raise it up a bit i'm hoping it will pop it out thanks for the help
Old Jan 9, 2005 | 01:34 AM
SKDRCR's Avatar
Do you see it in either of these pics?
Old Jan 9, 2005 | 03:21 PM
yOnKiNaToR's Avatar
Default Re: suspension bolt difficulty (SKDRCR)
no b/c that's the front end pic.
it's no. 31 bolt on both side of the rear of the car that i'm having trouble getting out. i have to replace that bushing and have to get that bolt out to get to it. i got the nut off and the bolt turns but doesn't come out so i've tried using a prybar, a hammer, you name it.
i also have a problem getting no. 49 bolt out of the trailing arm.
any help appreciated. need help quick!
Old Jan 10, 2005 | 06:37 AM
yOnKiNaToR's Avatar
bump for the mornin crew
Old Jan 10, 2005 | 09:14 AM
Pr0jektLude's Avatar
try heating the bushing up, while using something to pry or knock the bolt out with...heating the bushin should loosen the tight *** grip it has on the bolt...i had this problem with a 96 civic and thats what worked for me.
Old Jan 10, 2005 | 11:06 AM
yOnKiNaToR's Avatar
Default Re: suspension bolt difficulty (Pr0jektLude)
well, the weird thing is, i can turn the arm and the bushing spins. i can turn the bolt and the bushing just stays there so i would assume it's not stuck to the bolt. that arm is close to the gas tank isn't it? i don't know if i'd feel right using a blow torch so close to a gas tank like that. it's also right near the pipe connecting the gas tank and to where you fill it.
i'm wondering if a torch doesn't work if i could drill through the top right off the bolt or maybe drill through the bolt and split it.
Old Jan 10, 2005 | 03:59 PM
yOnKiNaToR's Avatar
ok, i took the whole subframe off to get to it easier and i've: blow torched it,hammered it with a BFH, and used a 6 foot bar on it but the bolt continues to spin but will not seperate itself from the inner part of the bushing. should i just find someone with a saw and cut the damn thing off? i think i'm just gonna take it to a shop tomorrow.
Old Jan 10, 2005 | 05:45 PM
92LudeSI's Avatar
I had this problem as well. The weird shape is for adjusting the rear toe. I just took it to the shop and had them deal with it. I hammered and heated for hours that damn thing was glowing red hot but still wouldnt come out of there. I took mine to an alignment shop and they aligned it afterwards as well because you will need it. Good luck man!
Old Jan 10, 2005 | 08:34 PM
yOnKiNaToR's Avatar
Default Re: (92LudeSI)
i think i might have stripped one of those alignment bolts..god damn it!
yeah, i'm taking it to a shop tomorrow...someone that has some heavy duty tools and isn't a 130 lb. weakling like myself.
thanks for all the help once again guys.
jksmith
Jul 25, 2009 07:50 AM
Homotor
Mar 21, 2008 12:47 PM
B18G
Jan 6, 2004 08:48 PM
Matt B
Apr 20, 2003 07:12 PM
