MSD Ignition and Starting problems
Old Jan 7, 2005 | 05:53 PM
K-Spec's Avatar
Default MSD Ignition and Starting problems
Hi,
I was wondering if anyone here is running an MSD Digital 6 on their lude. If so, have you had any problems running or starting your engine? I'm having problems with mine (right now, the car will not start, but the engine turns). There is spark, so it couldn't be the MSD Ignition, but can it be the MSD Blaster SS coil or anything else? Help...
Old Jan 7, 2005 | 07:09 PM
PreLuDeSiR's Avatar
Default Re: MSD Ignition and Starting problems (khalal538)
check the coil, it may be faulty
Old Jan 7, 2005 | 09:47 PM
K-Spec's Avatar
Default Re: MSD Ignition and Starting problems (PreLuDeSiR)
Is there any way to test the coil without having to buy a new one?
Old Jan 8, 2005 | 01:19 AM
@ries's Avatar
put the stock coil back on and see if it starts.
Old Jan 8, 2005 | 10:48 AM
Under_Pressure's Avatar
Default Re: MSD Ignition and Starting problems (@ries)
Same thing happend to me. Me car would not start sometimes. I found out by bypassing the msd and going back to stock that it would turn on. I bought a new coil and replaced the old one still noting.So the last thing was the msd box. I sent it to there repair shop and its worked ever since. They did not tell me what was wrong with it but I always keep my OEM coil in the trunk just in case! O BTW I have a MSD SCI box.
Old Jan 8, 2005 | 11:35 AM
K-Spec's Avatar
Default Re: MSD Ignition and Starting problems (92h22alude)
Hey
Does it go out on you often? And which coil are you using? Anyway this is my second box, the first one fried on me...so if this one goes, i'm just going to remove it permanently.
Old Jan 8, 2005 | 03:48 PM
ALTERED4's Avatar
the digital 6 with an hvc killed my ignitor after about 8 months of use...
Rodzknight
Jul 3, 2006 01:02 PM
Undercover_Skank
Apr 11, 2005 08:51 AM
Blown90hatcH
Jan 10, 2003 09:11 PM
SIK IN DA HED
Jul 31, 2001 01:25 PM
