Intermediate/Half shaft problem?
Old Jan 11, 2005 | 05:41 PM
yOnKiNaToR's Avatar
Default Intermediate/Half shaft problem?
As i'm in the process of doing this huge bushing/brake/axle job i pulled both axles out b/c i need new ones and while i was down there, i saw what looked like fresh tranny fluid all over the bottom of the tranny. i noticed it awhile ago and wiped it off and if i knew if it came back it would be a leak of some sort. well, it's back again and it's right where the intermediate shaft connects to the tranny.
what does that mean? i noticed on the IS that the outer metal piece is bent. i assume that allows the fluid out of it but i also read that it's some kind of seal that causes the leak. i'm not really sure what i'm looking for to replace as i've never dealt with an IS before. i don't have the money for a new IS and i hope it's just a seal or something.
here's a pic of what i'm talking about. it's circled in red where that bent piece is and where the fluid is presumably leaking from. any help on what to do with it would be helpful.
.orig.jpg for a bigger more clear pic.
Old Jan 11, 2005 | 05:47 PM
yOnKiNaToR's Avatar
Default Re: Intermediate/Half shaft problem? (yOnKiNaToR)
also, i forgot to ask this:
is it absolute necessary to drain the coolant to take out the axles? i removed them without draining the fluid and it leaked a little fluid out the holes but nothing big. i just recently changed my fluid so i found no good reason too.
Old Jan 11, 2005 | 06:09 PM
Hawkze_2.3's Avatar
Yep, there is a seal where the int. shaft goes into the tranny. I replaced these last time I took off the tranny...very easy to do while you're in there.
Number 15---->http://www.hondaautomotivepart...USING
Old Jan 11, 2005 | 10:59 PM
yOnKiNaToR's Avatar
Default Re: Intermediate/Half shaft problem? (Hawkze_2.3)
so does the bearing and the seal just pull right out? i might as well get 2 of 'em and do both side real quick if it's easy.
what about that bent metal piece? i didn't see that listed as a seperate part i could buy. think it would be a big deal?
Old Jan 12, 2005 | 06:15 AM
Hawkze_2.3's Avatar
You'll have to pry out the seal with something thin. I used an angled razor blade...the seals are pretty sturdy so they kind-of pop out. I wouldn't really worry about that metal peice, mine's bent, too
Old Jan 12, 2005 | 07:53 AM
yOnKiNaToR's Avatar
in the pic it looks like you only need one and it says that required qty. is only 1 yet on slhondaparts.com, they list 2 #15's. does that mean one is for left side, one for right side?
Modified by yOnKiNaToR at 12:04 PM 1/12/2005
Old Jan 12, 2005 | 08:10 AM
Hawkze_2.3's Avatar
Well, there's one for each side, but they're different sizes and part #'s. The only thing I can tell you for sure is get the one from Majestic...
Old Jan 12, 2005 | 08:16 AM
yOnKiNaToR's Avatar
what about # 13 in that pic? it looks likes it's the seal to the other side.
anyway, majestic doesn't have a part # on there stuff do they? i can't seem to find it.
Old Jan 12, 2005 | 08:19 AM
yOnKiNaToR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Well, there's one for each side, but they're different sizes and part #'s. The only thing I can tell you for sure is get the one from Majestic...</TD></TR></TABLE>
btw, the 2 #15's on slhondaparts are the same size. that's why i'm not sure which part # to use.
Old Jan 12, 2005 | 08:20 AM
Hawkze_2.3's Avatar
Yup, it's #13.
Old Jan 12, 2005 | 08:35 AM
yOnKiNaToR's Avatar
ok...i'll get # 13 and i'll pick one of the # 15's to use..
thanks for the help!
NightHawkBlack-R
Nov 3, 2008 03:34 AM
Linh.
May 25, 2007 11:07 AM
krazycivic4u
Jun 25, 2006 11:11 AM
Rod.
Nov 5, 2004 12:48 PM
