engine cleaner?
Old Jan 10, 2005 | 02:15 PM
themex77's Avatar
Default engine cleaner?
have any of you guys have heared of a an engine cleaner seizing an engine?
Old Jan 10, 2005 | 02:22 PM
clemsoncb7's Avatar
Default Re: engine cleaner? (themex77)
No, i haven't. But what usually happens is water from rinsing gets into the distributer and ***** up the firing. It will eliminate the charge meaning loss in cylinder(s).
Old Jan 10, 2005 | 02:23 PM
98TypeSH's Avatar
If you pour to much of any type of liquid in your motor you can hydrolock it. ( minus say fuel) Last i checked engine cleaner or restore or what have you, doesn't compress/combust to well. Its pretty safe to assume if you dump excessive amounts in your motor, yes you could seize/hydrolock it.
This is based on simple theory. I personally have never dumped engine cleaner in my compression chambers or anything.
Engine Brite or a Surface cleaner, obviously wont do any damage.
Old Jan 10, 2005 | 03:06 PM
themex77's Avatar
Default Re: engine cleaner? (98TypeSH)
so how would you fix that?
k2GM
Engine Management and Tuning
Nov 9, 2010 04:12 PM
Armstrong57
29
Sep 16, 2007 11:44 AM
